Results 3,831 to 3,840 of 5002
- Apr 2010
- 131
September 8th, 2013 07:56 AM #3831If you can blank right after you left casa the better. However, take note that this procedure will void your warranty. Also, for some, this gives check engine light, and *may* cause limp mode. Hence, better make an internal arrangement with your SA not to put on book this mod. Slotted blank is best for easy install and removal. OBD2 tool at hand is a great help.
HTH.
good morning tsikoters.
Sent from my S3 using Tapatalk 2
- Aug 2009
- 181
September 8th, 2013 12:07 PM #3832Mga sir tanong ko lang nawawala ba ang wheel alignment pag nalubak ka ng medyo malalim or na humps ka? ako kasi na humps ng mga 40-50kph with 3 passengers aspaltado kasi and kakulay ng kalsada at umuulan pa kaya diko napansin and after that parang napansin kong nagiba pakiramdam ko sa manibela & the next day medyo may kabig na sya sa left or is it dahil nagpapalit ako ng 20" rims with 265/50/20 tires? sa mga nagpalit na dyan ng 20" rims nagpa wheel alignment ba kayo after or wala namang nagbago sa handling ng rig nyo? thanks mga sir..
- Aug 2009
- 181
September 8th, 2013 12:40 PM #3833mga sir isa pang tanong, pagba nagpa camber eh may mavovoid na warranty? nung nagpacamber kasi ako dati ng kotse may inacetylene at kinikil sa may pinagkakabitan ng turnilyo kumbaga pinalaki yung butas.
September 8th, 2013 01:19 PM #3834
dapat pag palit mo nang bigger tires and rims w/ lift nag pa camber/toe alginment kana kaagad. yan usually ang ginagawa after changing into a different size of tires and a lift. about sa lubak nman, i dont think na masisra na ang suspesion just by a few lubak lang. i tried to run 80-90kph on 4H sa light to meduim unpaved road but ok naman and wlang naging probema sa wheels ko. just bring your rig to a trusted casa for wheel balancing and alignment.
September 8th, 2013 02:33 PM #3835
Please recommend where we can buy EGR blanking plates and Oil Catch Can. Thank you.
- Aug 2009
- 181
September 8th, 2013 03:47 PM #3836thanks sir, actually hindi naman po ako nagpa lift, change rims & tires lang and ung humps na nadali ko medyo mataas at medyo mabilis din ako nun. Galing ako Master Fix sa evangelista (recommended kasi sa ford ranger forum na ok daw sa bigger tires sa pick up) and ang camber result
-1 sa left & +9 sa right kya need daw i camber kasi lagpas sa +5 tolerance kaso mahahalata daw sa casa pag nacamber na & baka warranty issue
kaya hindi ko muna pinagawa observe ko nalang daw muna pero sa wheel align ok naman ang result within tolerance daw. btw 500 lang wheel align sa kanila & 2.5k camber w/ wheel align pero sa iba 1.2k wheel align at 1.8k camber pero patingnan ko din muna sa mega motion sa banawe
baka dun naman wheel align lang lumabas hindi ok hehe .
- Jul 2013
- 193
September 9th, 2013 01:38 AM #3837Sarap ihataw si strada na naka egr blanking ano mga sir? Pero paano sa emission testing, kahit di na kaya alisin yung blangking plates, ok lang? Kasi pansin ko lang parang tumapang yung amoy ng exhaust gas mula nagblank ako. Lalo na sa cold starts..
- Apr 2010
- 131
September 9th, 2013 08:21 AM #3838Just renewed my registration last month.
Emission test with EGR blank is 1.12. 2.2 max required ng LTO. That's on Petron Diesel Max. No 2T.
- 217
September 10th, 2013 10:06 AM #3839
- Jun 2013
- 179
September 10th, 2013 11:39 AM #3840
Xiaomi E-Car
