i don't know much about the tires you've mention. i'll just give some overview na lang. stock gls tires are 245/65/17 the monty has a 265/65/17. if you think those tires are heavier than the stock glx? well, later models of strada share the same engine w/ the monty (vgt or non-vgt) except for the monty se, so basically there's not much of a difference if you switch to oem tire size of the monty/gls. pros? wider tires means more rubber on the road and bigger tire looks good
sir lakers24: 265/65/17 is still safe for strada. a lot of guys and even a friend of mine switched to oem monty size tires and rims.
