Results 3,561 to 3,570 of 5002
- Aug 2010
- 24
- Aug 2009
- 181
July 27th, 2013 02:21 PM #356261K quote sakin ng wheel gallery black rhino Mojave 18" (out of stock ang rockwell sayang) with saffiro AT tires, talaga bang ganun 4k lang diff nya sa 20"? kala ko kasi mas makakamura ng malaki sa 18" tsaka baka matagtag na masyado or mas madaling mabengkong ang 20" kaya 18" lang sana gusto ko pero kung sa 4k na diff mas ok na kayang mag 20"? salpak nalang ba yun at waalng sayad? kumusta naman ride nyo mga sir after nyo mag 20"? tsaka pala 8k lang daw trade in ng stock kala ko10k
July 27th, 2013 10:05 PM #3563
20 nyo na sir kung sa road lang nman. Konti lang naman difference.. di naman mabebengkong yun basta basta..ingat lang sa lubak na malalim at makapal pa naman yung gulong nun. If gusto nyo makamura e mag 17 or 18 na lang kayo.
ok naman ride ng 20 mas feel mo lang na mas kapit sya sa road kumpara sa stock. Matagtag naman kahit yung stock nya e. Yup, salpak na lang yun. so far, wala naman akong problema sa gulong ko.. 8k nga lang dun. trip ko din yung rockwell e.. mojave na lang available?
July 28th, 2013 09:17 AM #3564
I,m used sa engine warning light,sometimes on & off but lately it stayed on,so yesterday I brought it sa Diamond service Center just for routine check up,I almost fell from my seat NGO ipakita sa akin ang mga faults & cost including labor. I need to replace the fling- EGR sensor, Inhibitor switch ng drive gears,alternator belts. Materials & labor pitot 23k. I asked the supervisor what causes the break down ? Was there abuses on my part, ignoring the warning light for along time? His answer is that it reaches the point of material fatigue nothing can alter the process. I checked the replaced parts it's not sealed pledge kong buksan para pag aralan kasi it's parts is almost 8k each (excluding young belt). Favorite ng wife ko ang strada than our brand new trailblazer kaya I need it to keep always on top shape
July 28th, 2013 09:46 AM #3565
My friend is selling me his chrome 20" rim with 265/50 tire, sa tingin nyo babagay ito sa gemstone grey.
- Aug 2010
- 24
July 28th, 2013 12:35 PM #3566Sir G01, gni2 din ba wiring ng sa u? Wlang problema sa linya ung pagloloop ng bright sa dim pag nag short na ung 30 & 87? Kc babalik un sa stock relay ng dim di ba sir although nakaoff na ung relay pag nagshift ng bright.correct me if im wrong sir..
- Aug 2009
- 181
July 28th, 2013 01:12 PM #3567thanks sir, yup mag 20" na nga lang ako, pero try ko din umikot ikot muna sa ibang shops rockwell kasi talaga type ko and wala sila kahi anong size, mojave at moab nalang available kaso mojave lang me matte black pero negative offset daw kaya lalabas mga 3" yung gulong. sa inyo ba sir labas din gulong? ok lang ba tong negative offset? kasi kahit this aug daw wala pang parating na positive offset pati rockwell eh or baka sabi lang nila yun para kunin ko na agad yung mojave
July 28th, 2013 02:50 PM #3568
hi guys, ask ko lang po sana kung papalitan ko po yung tires ko lang ng masmakapal na goma hindi po ba mavovoid warranty ng strada ko po?
and ano po kaya pros and cons ng masmakapal na goma like 245 75 16 and 265 70 16 VS sa stock na 205 80 16?
strada glx v limited mga 2 weeks old plang po kasi sya.
TYVM
July 28th, 2013 05:00 PM #3569
2 relays po yung sa akin kasi pinalitan ko ng bixenon HID projectors yung high beams. Yes sir, naka off yung stock na relay switch ng dim during high beams so yung power from the 87 ng additional relay ay hanggang doon lang siya sa "87" din ng stock relay at hindi na tatagos kasi walang continuity ng "87" at "30" sa stock relay.
July 28th, 2013 07:58 PM #3570
Mahirap na nga lang humanap ng mga designs nyan..sa wheel gallery na pinkamarami e. pero try mo din.. alam ko may BR din sa sny customs, na sa 85k ata dun nung nag paquote ako tapos less 15k if trade in yung stock.. kaso konti lang din ata designs nila. Try mo sin sa BCC wheels. Meron din ata dun. di ko lang alam magkano dun.
yan din ata yung tnry ni sir fourstring na -12.. +12 yung akin at labas na rin yung gulong nun..wala naman daw problema dun basta walang sayad, mas maganda, malapad tignan ride nyo. yun nga lang, talsikan putik nun sa katawan ng strada nyo.. yung sa akin, konting madaanang tubig e abot na hanggang door handle.
Or none of the above? We've had Ferraris and Lambos burn in SLEX and NLEX in the Philippines...
Hybrids and EV
