Results 2,161 to 2,170 of 3019
October 9th, 2012 08:24 AM #2161
Tsikot Member Rank 1
- Jul 2009
- 4,090
October 9th, 2012 09:43 AM #2162in that case, tires sidewall will be out by 19mm
(hairline bigger than my mid-finger)
while back of the tires sticks in by 11mm[if you can put any of your fingers between the tire/shocks spacing(oem)definitely no rubbing issue on the shocks]
and is just taller 6.65mm(up and down), so sir noels rig is taller 6.65mm.
(smaller compared to our key blade)
and if speedo not adjusted by obd, actual speed 100kph, reading is 102kphLast edited by zix888; October 9th, 2012 at 09:59 AM.
- Nov 2009
- 1,756
October 9th, 2012 12:28 PM #2163Very impormative Zix, thanks.
Actual lang sukat ko, 10mm-15mm naman sa tantshahan.(smiley)
If possible, may you share the computation?
- Jul 2009
- 4,090
October 9th, 2012 01:28 PM #2164we will use the tires width , since they wider than the wheels.
oem tire width is 215mm, while the 19" is 245mm, which is 30mmm wider than the oem( 15mm on each side). if you got an offset same as the oems, which is +46, 15mm lang sana ang ilalabas ng tires, but since mas mababa ang offset by 4mm, i-add mo siya sa 15mm na inilapad ng tires mo, that is 19mm. same is true with the back part of the tires, i-less mo yung 4mm sa 15mm, thats is 11mm.
sa over all dia naman,
constant na yung rim dia 19" plus yung thickness ng tires. now yung kapal nung goma is indicated already sa 245 45, this means na yung kapal niya is 45% nung lapad na 245mm. 245x.45=110.25mm . yan ang kapal ng tire, pero when you measure the dia of a wheel/tire, 2 portion ng goma, sa taas and yung nasa bottom, so multiply 110.25x25=220.50mm, i-convert mo sa ", 220.5/25.4= 8.681". add the wheel dia. and this, its 27.681"
oem is only 27.157"
their difference is 0.524" also equal to 13.3mm(overall) . di ba hatiin mo sa 2 kasi tire portion is top and bottom, kaya 6.65mm lang actual na itataas ng oto mo.
October 9th, 2012 02:06 PM #2165
Ask ko lang sa mga GLS model may nag pa install na ba sa inyo na gawing HID ang headlight? Both low & high beam? OEM ba ang inilagay? Yung talsik ng ilaw katulad ba sa SE na superwide din? Magkano kaya? Kasi 14k ang charge skin ng casa.
Sent from my GT-P7510 using Tapatalk 2
October 9th, 2012 02:24 PM #2166
walang bearing yang upgrade mo if you're eyeing for a "wider" throw. Madaya ang SE kasi me extra bulb sila (below the projectors) specifically aimed sa tabi (for a wider throw). :D
if you notice mas maliit yun "space" nun projectors to give way sa extra bulb below...
not like with other variants:
yun magaling kong SA even suggested basagin ko yun headlights ko - claim sa insurance and palitan daw nila ng pang SE. Hahaha. Lintek na suggestion yan.
October 9th, 2012 02:31 PM #2167
- Nov 2009
- 1,756
- Jul 2009
- 4,090
October 9th, 2012 03:19 PM #2169
October 9th, 2012 03:30 PM #2170
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
