Results 2,171 to 2,180 of 3019
Tsikot Member Rank 1
- Jul 2009
- 4,090
October 9th, 2012 03:43 PM #2171
October 9th, 2012 03:50 PM #2172
hmmm. I also have a monty but, basically they're just the same naman na projectors on low-beam, hi-beam on 'regular' reflective housing. Kung hid upgrade, probably mas-lalayo sya kesa lalapad ang buga UNLESS they'll have to tweak yun beam 'palabas/wider' throw. (Based on my knowledge on oldskul HL na pwede mo manual adjust on non-motorized-auto-leveling headlights).
if you ask them to trade-in your stock GLS HLs and replace with SE HLs, magkano kaya?
October 9th, 2012 04:23 PM #2173
- Nov 2009
- 1,756
October 10th, 2012 05:56 AM #2174
- Jul 2009
- 4,090
October 10th, 2012 08:05 AM #2175
October 10th, 2012 08:17 AM #2176
- Jul 2009
- 4,090
October 10th, 2012 11:50 AM #2177
- Apr 2010
- 17
October 10th, 2012 07:06 PM #2178You can change the tire diameter in the ecu. I was able to get a cable to reprogram the ectas in the ecu. Just measure the tire diameter then input it in the ecu.
October 10th, 2012 07:47 PM #2179
October 10th, 2012 08:07 PM #2180
Di daw pwde trade-in...bawal daw, ibenta nlang daw sa labas. Ska suggestion skin yung low beam nlang daw palitan pra yung high beam magamit ko raw Kpag umuulan o foggy.. mahihirapan daw ako kung lahat hid? Totoo ba? 7K + yung lowbeam ksama na labor.
Turbo timer yung feature na yan sa Everest? Sana default feature yan sa mga naka turbo na sasakyan.
0dometer problem
