Page 138 of 302 FirstFirst ... 3888128134135136137138139140141142148188238 ... LastLast
Results 1,371 to 1,380 of 3019
    Nov 2006
    #1371
    Quote Originally Posted by carofsteel View Post
    sinubukan ko sir idownload yung update ng software sa SD card then isalpak pero nageerror. Same din tayo ng tanong dati kasi GLX din akin. Di pwede basta icopy na lang yun software sa SD card. Kailangan yun SD card na may software na ang iuupdate mo. Pwede siguro may mag offer dito sa mga may GPS na icopy yun SD Card nila to other SD card hehe. Kasi mahal pag sa casa bibilhin. Huling tanong ko is 6k SD card lang na may kasamang software. Pwede mo na ibili ng separate GPS unit yun.
    sinubukan ko rin yun sir, error din nakuha ko. Nagtanong na ako sa casa, 15k daw daw yun SD card na may software.
    Nov 2006
    #1372
    Ano model ng AVT HU mo? check first kung GPS ready yan. Pagka alam ko some models hindi GPS ready.
    AVT IMD-6307T yun model sir. GPS ready na.
    Nov 2006
    #1373
    Quote Originally Posted by Noel Salisipan View Post
    na-contact mo na ang winterpine bro?
    Malapit lang din dun yung nagaayos ng GPS, tanong mo na lang kay Angela.
    Nagtanong na rin ako sa Winterpine sir. Sabi nila wala raw sila separate na GPS software for AVT IMD-6307T. Yung mga bagong unit na meron pre installed na software ang meron.
    Dec 2011
    #1374
    Quote Originally Posted by cerrealkiller View Post
    AFAIK, Winterpine dont have the software but they know the office that are concerned with the AVT including the software.
    Try to ask, they show me before the place but not interested that time.
    #1375
    If your unit is navigation ready, all you need is just an updated map specifically designed for your avt unit. Its roughly around 300mb file and definitely will not cost you 6k just to have it. If your unit is the same with the SE which i believe has a navigation, all you need is that sd card, just copy it. Also dont believe them when they said you need a special sd card for that, i have used old sd cards from my "baol" and just download and follow the procedure from inav.ph, for as long as you have the correct map for your avt, its perfect. I have also tried downloading maps of different avt model, the maps are distorted. The question is, does inav.ph have the specific map your avt needs, if yes , well and good, if not, you are trapped as of now
    Dec 2011
    #1376
    Guys! Advice naman po. Newbie palang ako about sa mga cars but I have rred asx :D Question ko lang. Anong gas kinakarga nyo and ano advantages/disad? Gamit ko kasi sa ngayon petron extra unleaded. Tapos may napansin din ako sa ASX ko. yung sa Handbreak nya. Mejo maluwag.mejo Na momove sa side. Pwede ba yun pasikipan? Tnx sa makakatulong
    Sep 2011
    #1377
    Quote Originally Posted by sole_gemini View Post
    May discussion na dito about sa gas na gamit nila try to read previous posts. Di lang gas matutunan mo. About sa handbrake medyo maluwag nga at nagagalaw from side to side. It doesn't bother me pero gusto ko din ipa check kung pwede pahigpitan. Sa next check up na lang siguro.
    #1378
    Guys! Anong gas kinakarga nyo and ano advantages/disad? Gamit ko kasi sa ngayon petron extra unleaded.
    RON 93 to 100 are all fine & no big difference in performance. Me, I use premium.
    The same with me but its fine & not worse. Dont use it sideways, intead back & fort. (smile)
    I advice to let it that way, if you will try or somebody will repair for it, expect some parts to be dismantled. Might repair your worry but it may dis allign or damage some of its adjacent part(s).
    Dec 2011
    #1379
    Guys! questioon ulit. Pano ba talaga gumagana yung Auto door lock? Meron ba tayo n2? na notice ko lang nag autolock ASX ko dati. umalis lang ako sa garahe ng hindi naka lock then after a few seconds naka lock na yung doors. Pero parang hindi laing ganto? HAHA. Pano ba talaga to nag wowork?
    Tapos survey lang. Ano favorite nyong accessory sa ASX nyo? aside sa gulong :D yung hindi din mavovoid yung warranty Yung headlamps nakakatemp palitan T.T
    Sep 2011
    #1380
    Sa GLX ang alam ko wala ewan lang sa iba. lol . Pero pag nakalock sya at press mo unlock sa key at di ka naman bumukas ng isang pinto maglolock ulit sya.
2010 Mitsubishi ASX Crossover
