Results 11 to 20 of 22
- Jun 2005
- 3,774
July 6th, 2017 04:35 PM #11May kakilala ako literally living under a cellsite. Nandun sa roof ng building nila since early 2000s.
Ang side effect lang eh sobra talino nila, magaganda pa mga anak.
Siguro nga masama talaga. Haha
BANNED BANNED BANNED
- Sep 2014
- 8,492
July 6th, 2017 07:38 PM #12
- Jul 2013
- 421
- Jul 2013
- 421
July 8th, 2017 12:49 PM #14Everything on our planet is magnetic. Even the birds, whales and dolphins know this. Sana, they can come to Tsikot and make this statement. Sasabihin nila, “Mga………..”
In 2002, I discovered that water could be made acidic or alkaline with a tetrahedron. I constructed a tetra with 6 pieces antenna alum tubing, each leg is 14”. The 4 points were riveted. I borrowed a digital PH meter from a local university science lab.
I filled a 1.5 ltr cola drink (plastic/glass) with tap water; the later is better, imo. This plastic bottle of water was placed inside the pyramid. When the pointed side of the P is aligned towards the N pole, the water become acidic. When the flat side of the P is aligned towards the N pole, the water become alkaline. Ph was formerly 6.6. After 24 hrs, it became 7+.
Why? Can anybody explain this phenomena? I deduced that only the earth’s magnetic field could affect the water. No sunlight to affect the water. But the earth’s field is so weak (1 gauss) that only a compass will show its effect.
I always put this bottle near me and drink from it (every 2-15 days). I am assured that the PH is 7 or better.
- Jul 2013
- 421
July 9th, 2017 09:41 AM #15[QUOTE=pyramid00;2850212]
Why? Can anybody explain this phenomena? I deduced that only the earth’s magnetic field could affect the water. No sunlight to affect the water. But the earth’s field is so weak (1 gauss) that only a compass will show its effect.}
Please, mga smart TS; yatta, lsb, niky, uls, dr d and a host of others. Since 2002, i do not have an inkling about this phenomenon. I only know that the earth's magnetism had an effect on the water. Hanggang duon lang.
May I suggest that your HS or college kids perform this experiment in their science lab? Ano kaya ang ma-research nila? Maybe, after 15 years, maybe, this phenomena will be partly or fully answered. Thank you.
- 52,933
July 9th, 2017 10:57 AM #16i am always curious, as to what happened to the pH of the second bottle of water, but without the tetrahedron....
did its pH also change?
were the usual purity and contaminant precautions observed, when the experiment was performed?
tap water? as in, slightly chlorinated water? isn't that slightly acidic? and does the water turn slightly alkaline, as the chlorine disappears, evaporating or reacting with its surroundings?
i seem to have forgotten my basic chemistry...Last edited by dr. d; July 9th, 2017 at 11:07 AM.
- Jul 2013
- 421
July 9th, 2017 03:04 PM #18You mean, the control? Ph not changed. It was isolated more than a meter away. Experiment was done in 2002. I always have this water within reach. Note: if metallic objects are near the P, no ph change. I will try to read my old notes about this experiment. Some fascinating revelations about the pyramidical shape. I think, it's in the pyramid, but how about it's alignment?
No precautions on purity and contaminant.
Water came from faucet, water pump direct from the ground. 20 feet pipe driven to the ground.
- Jul 2013
- 421
July 9th, 2017 03:10 PM #19
- 52,933
siya nga. i tweeted the mmda and they replied it's suspended nga.
Traffic!
