Page 22 of 71 FirstFirst ... 1218192021222324252632 ... LastLast
Results 421 to 440 of 1411
    May 2008
    #421
    Quote Originally Posted by blueguy View Post
    ^^^ Yup....pag cast-in-place or buhos yun mahirap tanggalin...but pag pre-cast panels lang...easy lang yun. Usually light weight naman ang mga yun...
    Hi,
    A different thing, my wife suggests i-paint ko daw flooring ng garage namin. Is there a particular paint for the purpose? Madali lang ba gamitin? How bout the price?
    #422
    Mga gurus, where can i get a the following: Environment, Health, Safety Requirements Certificate?
    Jul 2005
    #423
    Quote Originally Posted by tatayniisay View Post
    Hi,
    yong contractor na gumawa sa amin, ni-paint nya yong flooring ng deck namin ng parang rubberized paint, parang yong ginagamit sa mga gasoline stations, baka pwede yon.
    Jul 2005
    #424
    Tanong din po. Can you suggest:
    1) a good screen door maker para sa main entrance
    2) a good mirror maker, yong medyo makapal naman na mirror not like those being sold in ACE or Handyman
    #425
    Quote Originally Posted by swordsman View Post
    sa mga glass and aluminum store madami choices na mgaganda ill recommend ung tinatawag nilang AMPLIMESH SCREEN DOOR NA ANALOK...un ang uso ngayon for main door..usually it ranges from 5k-7k..madami din dun mga mirrors me mga beveled with shape pa..
    #426
    Am new here in the country and was wondering. If you have a lot of a certain size someone said you must allocate X amount of pesos per sqm for building to the architect. Now lets say that you dont construct on entire lot but make a big gardern. Does that same rule apply? For example you intend to build on a lot of 700sqm. If you only allocate 400 sqm of it to the house structure should you still compute against the 700sqm?
  7. #427
    Running rate yata ngayon is about P25k per square meter. What's included are all covered areas. So essentially, floor area (not lot area). Kung covered parking, covered utility area, servants quarters or outhouse, they usually include that in the computation.
    It's more of a guide rin lang.
    #428
    Ang mahal na talaga,- P25K/sqm.... tsk tsk tsk.... And this is floor area, so if you have a second floor, and a third floor/attic then they count in the total floor area....
    6404:pump:
    Jun 2007
    #429
    Naturally cost per square meter can vary depending on materials, design, non-liveable areas and options and the cost is around 25% higher than the floor below (if both floors are identical in construction.)
    #430
    Wow 25k/sqm is expensive. And that is based on FA right? Not LA? Plus it doesnt include ba items like Toilets? or is that factored in?
    Since Materials come into play the 25k computation is high end materials? What would the percentage dropes be for subsequent lower end materials?
    Jul 2005
    #431
    Quote Originally Posted by vicman View Post
    thanks. would you know any particular store or area to look? can't seem to find my pldt directory...
    #432
    Quote Originally Posted by paolorenzo View Post
    25k/sqm na:exclaim: i recall about 10 years ago nagpagawa ako mga 8k/sqm lang and it already includes the following (IIRC):
    • flooring - 60 x 60 class AA marble
    • roofing - long span color roof (yun ba tawag dun?)
    • gutter - oversized stainless steel
    • windows - aluminum single pane sliding type
    • toilet & bath - colored american standard with floor & 6 ft high mariwasa tiles glazed/color tiles (w/ bath tub in masters bdrm)
    • cabinets - 3/4 marine ply w/ moulding and duco paint in kitchen and all bedrooms
    • 4 bedrooms and 3 full t&b
    • separate living/family/dining/nook/kitchen/walk-in pantry areas
    • paint - indoor/outdoor boysen paint
    • doors - two thick (forgot the wood type)/bleached w/ glass inserts for main & back door; two-panel sliding glass door sa kitchen towards patio and regular doors for all other rooms
    • others - atrium with glass/concrete combo walls/doors
    hmmm.... napaisip tuloy ako, if 25k ang newly constructed price then take into consideration ang 10 years depreciation out of a 50 year (default life span) or 20%, eh di mga 20k/sqm x floor area ang computation kung ibenta ko sya.... okay pala ano! plus the cost of the lot with improvements such as perimeter walls, dirty kitchen, bodega, cemented garage.
    bro paolo, salamat sa info ha at nagkaron ako ng idea kung ano pwedeng gawing project..:thumbup:
    #433
    Mga sirs medyo off topic. Can you recommend me someone na nasa mobile cranes business? My contact is looking for 300 tons and 500 tons used mobile cranes. Any Brand will do. If you got contacts who sells used cranes kindly refer them to me na lang po. thanks.
    #434
    Mga peeps,
    I need ideas sa pagpagawa ng maliit na bar counter sa bahay. Baka may alam kayong magandang design at magkano kaya ang cost nito. Or meron ba kayong alam na magaling gumawa ng ganito? Paki-send naman po ng pics.
    TIA
    Jul 2006
    #435
    Wow!!!25k per sqm is too much mga peeps. You can still get 10k to 15k per sqm. Some are offering no d/p pa nga. But anyway doble ingat din at we have to sure doon sa Construction Company kung legitimate talaga sila.
    Apr 2004
    #436
    Question guys, What is the usual fee for a building permit (palakad)
    we are being charged the amount of 68k all in for a 2 storey house FA 200+200 here in qc.
    is it a reasonable amount?
    Apr 2004
    #437
    up lang, sana may makapag advice.
    Apr 2004
    #438
    Quote Originally Posted by v22 View Post
    if you have a contractor that knows the city hall very well, it will be much cheaper than 68k, otherwise it is the normal price.
    Apr 2004
    #439
    Quote Originally Posted by gearhead View Post
    usually 25k/sqm includes everything as long as you dont have bisazza tiles for your bathrooms. the rate per square meter depends on your desired finish and the current steel prices
    Apr 2004
    #440
    Quote Originally Posted by ocanursjr View Post
    10-15k? i highly doubt it. but if there is, check the materials. steel prices during the first 9 months of the year was unbelievable until the price collapsed last month. now is the good time to have your house built
House Constuction [Merged]
