That looks like a very sturdy tie beam ... so they also need to be anchored to an existing structure? (red arrow) ... what if the gate is farther away from any structure? ...
Ok thanks for the tip sir. I just wished I knew these before or during the construction.
how do you construct a dine-in business na pwede aircon at open-air?
Mr kabab at west avenue is a very good example so airy but its purely alfresco.
Pwede ba incorporate greenhouse style of housing? The sides and the roof adjustable?
Paging travahans....
not like this but just an idea sa future dine-in model para tuloy pa din buhay
yan partial opening lang.
Ang iniisip ko yung roof magiing bintana talaga ang bukas.
or this
Can anyone make a suggestion? Yung 2nd floor namin is concrete slab yung roof at wall. Now one side of the wall and the roof is absorbing too much heat during day time. Ang resulta mainit sa 2nd floor. I can really feel the temp changing pag umakyat na ko. I thought of putting an air condition on the rooms but it may be half as efficient kung ganito kainit.
We are planning to put a lot 3rd floor this may shield the 2nd floor roof from heat, yung wall na lang ang problem on what we can do so it wouldn't absorb heat so much.
Also the 3rd floor roof, what can we do so it wouldn't absorb heat too and end up with same problem.
So I would search for EIFS specialist? Thanks for the tip sir.
Parex/La Habra, Pleko, Dryvit are some of the brands you can search. Dryvit used to be carried by Republic Chem(Pioneer Epoxy) decades ago, but I guess they no longer are. I'm just not sure who the specialists are local to you. Homegrown Island Paints also has a vertically developed division. Even the fire-rated polystyrene insulation core comes from their in-house subsidiary.
Puwede external aluminum fixed blinds na facade gaya nito.
Aluminium sun shades - merlo
Aluminum sasalo ng sunlight/tapos external air cooling.
Puwede siguro pa sadya sa aluminum shop, tapos per panel install. Gawing typhoon proof.
Maganda malayo allowance sa wall para sa air cooling.
Puwede din external bamboo blinds.
Madalas nga lang sa balcony.
Kailangan i roll up kung may bagyo.
Edit: okay din pala bamboo cladding.
bamboo clad office building in france by monica donati
Puwede kung walang space sa trees na suggestion ay green wall.
Kailangan nga lang maintenance access.
Green facades | Urban green-blue grids
Taniman ang perimeter fence ng Japanese bamboo, abot shade nyan sa 2/F.
