Page 109 of 142 FirstFirst ... 95999105106107108109110111112113119 ... LastLast
Results 1,081 to 1,090 of 1411
    #1081
    May reason ba bakit 40psi in, 60psi out?
    Sent from my ONEPLUS A6013 using Tapatalk
    kung gripo lang ang ginagamit natin,
    low pressure is bear-able.
    but if we use the shower, less than 40 psi may not be efficient anymore. lalo na kung nagmamadali.
    my pressures are also 40-60.
    if shower is on the ground floor, with the right ducha (mine is basic model only), ok kahit 40.
    if shower is at the 2nd floor. 60 psi is ok. 40 is medyo nakaka-inis.
    shower at the 3rd floor at those pressures are... mag-timba na lang.
    #1082
    Im wondering, can the fittings, hoses, faucets, etc handle 60psi of pressure?
    Sarap maligo pag malakas pressure hehe
    PPR shouldn't give any trouble. They're tested to handle much higher pressures & are generally rated for 50years * around 70°C water temp.
    A word of caution, sunlight exposure & chlorinated water(esp heated) will accelerate PPR aging. Keep pipes covered or embedded.
    #1083
    If you re-line your plumbing, do the loop system, doc. The distribution line starts & ends at the pressure tank.
    Sep 2010
    #1084
    Hello sirs, question.
    Ganon ba talaga yung mga laminated floors? May ibang plank na may chipped color agad kahit sobrang ingat naman namin binaba yung mga item? Already talked to Wilcon at sabe nila hindi na pwede i soli since nabuksan na yung item.
    Possible kaya na i cover using wood filler with color na? Similar to touch up paint na ginagamit sa kotse.
    TIA!
    #1085
    Having my room redecorated - is wallpaper really more advisable vs repainting?
    Repainting is 35% cheaper.
    #1086
    Pano yang loop system?
    Signature
    #1087
    Larger than branch pipe diameter main line loops around your house. Start point is also your end point. Something like these...
    #1088
    Para ba equal pressure?
    #1089
    Better flow & pressure distribution. In a non-looped system, imagine a big usage, say laundry at the ground floor....this would rob a lot of the discharge flow rate & pressure for fixtures located post-laundry, esp the upper floor/s. If flow is limited, sometimes the end line fixture will risk not getting any water.
    #1090
    Travs what's better for bedroom walls - wallpaper or paint?
    Converting my off-white walls to blue-grey.
House Constuction [Merged]
