Page 59 of 142 FirstFirst ... 94955565758596061626369109 ... LastLast
Results 581 to 590 of 1411
    #581
    Meron nga pala kami mga kakilala na carpenters sa province who build houses there. Issue namin kasi baka di nila alam rules dito as well as the drainage system etc..
    Posted via Tsikot Mobile App
    Sep 2008
    #582
    Quote Originally Posted by raycom10 View Post
    Plan ko kasi pagawa ng bungalow house 2 bedroom lng. Is 300k enough?
    probably pwede sir kung sa province pagagawa, mdyo mura labor, sand & gravel as compared sa urban areas.
    #583
    kaya yan. but your house would look like a temporary facility / bunkhouse - but with a creative architect, anything is possible. I actually love minimalistic (or industrial) themed dwelling. (example below - i dont own the picture)
    #584
    P5000 for materials and P4000 for labor to prepare and paint one wall in a 25 square meter long area? What is done ba sa paint preparation?
    Hindi ako makaintindi ng 2d layout
    #585
    length and height of wall? also, what kind of paint finish would you want (rough or as-is from plastering or very smooth)
    #586
    mahal ntalaga yung paint
    #587
    Quote Originally Posted by poorprince View Post
    Height probably 9 ft. Yung length is the length of a 25 sq meter area, one wall na pahaba. They will use 2 coats. Rough finishing.
    #588
    ano po ba ang pipinturahan? wood or concrete?
    basic steps:
    1 - cleaning
    2 - sanding
    3 - plastering
    4 - "lason" (neutralizer for concrete)
    5 - primer application (1st - nth coating)
    6 - finishing
    7 - cleaning (tapos na... yehey!!!)
    some of the steps are required to be repeated in order to achieve the desired "finish".
    for most "small" painting jobs, material cost = labor cost.
    kadalasan kasi, kahit sa owner na lahat ng gastos sa materials tapos
    bayaran niya na lang 'yung taong gagawa (arawan), halos pareho lang talaga. HTH
    #589
    5k for painting materials is just about right for a wall 9ft (3m) high covering a 25 sqm area. Assuming the 25sqm (5m x 5m) area is covered on ALL 4 SIDES by a 3m high wall. You might need minimum 2 Gallons flat latex for primer coat and minimum 4 Gal of semigloss latex (2 coats) for the final coat. Plus minimum 2 gallons of concrete neutralizer to prepare your surface since its only "roughed" finish, plus misc items. Labor cost, 4k? dont know, i can haggle for 2k siguro if rough finish. I'm no expert though. Hope this helps.
    #590
    Quote Originally Posted by joemarski View Post
    basic steps:
    1 - cleaning
    2 - sanding
    3 - plastering
    6 - finishing
    concrete
    It's just one long wall. 5 days gagawin. Nagulat lang ako sa cost ng pag paint ngayon Puro algae na kasi yung wall e
House Constuction [Merged]
