Results 761 to 770 of 1411
- Nov 2017
- 1,748
February 26th, 2019 09:14 PM #761
February 26th, 2019 09:26 PM #762
- Nov 2017
- 1,748
February 26th, 2019 09:30 PM #763
February 27th, 2019 03:39 PM #764
February 27th, 2019 04:26 PM #765
Thanks guys. I read the DO and it checked out naman. Kinda bummed that cash bonds aren't accepted anymore but at least the final quote for the bond was a lot lower.
First quote was a multiple of the amount indicated in the DO though. Hmmmmm
Anyway am glad that's over and done with.
March 10th, 2019 04:54 PM #766
Hi again masters, inabutan ko yung workers doing the beam with rebars placed at the middle of both sides, pinaalis ko Ang had it placed at the top and bottom as the plan calls for 3 16mm for top and bottom. I just want to know if may silbi ba talaga ung nilagay nila na side bars, I searched the internet and all beams call for top and bottom rebars only. The foreman I got kasi doesn't know how to read plans and if I don't guide them, they will do things the way they were accustomed to
Sent from my Mi A1 using Tapatalk
March 10th, 2019 05:19 PM #767
Yes, in conventional applications, top & bottom beam bars handle the tensile stresses transmitted from vertical loads. Concrete alone can't handle tension. If a beam were designed to resist horizontal flexural or torsional stresses, then you'll need em where your crew initially placed em.
March 10th, 2019 06:52 PM #768
Sir Travs, I guess it was not a consideration, as the plan calls for just top and bottom bars, with extra bars for some beams. Thank you.
March 10th, 2019 07:05 PM #769
March 30th, 2019 10:31 AM #770
Question again Sirs, we decided to use drywall as room divisions, are these sturdy enough? Sabi kasi ng foreman, I need to use wood instead of metal for frames para daw di uuga. I was thinking if this is true or di lang sya marunong mag latag Ng metal frame
Taguig shouldn't be blamed over cancelled Makati Subway System -mayor | GMA News Taguig shouldn't...
Makati Subway. Completion date: 2025
