Results 611 to 620 of 1411
- Oct 2015
- 922
January 20th, 2016 11:48 AM #611Mas solid ang papa tungan ng tiles at flat mas matibay siya. Ok din kubg adhesive para mas maganda ang kapit.
January 20th, 2016 11:53 AM #612
Tiles have to lay flat or they'll be prone to cracking. A simple test after tile installation is to tap on each tile with an umbrella. If there is a hollow sound, the tile will crack sooner or later and should be repaired before turnover. Ceramic tiles need adhesive as theyre too light.
January 20th, 2016 12:11 PM #613
January 20th, 2016 12:31 PM #614
Ideally, the substrate should relatively be flat enough. That's why you use the thin set mortar(that's what it is called) using a notched trowel ( usually 1/4-3/8) of an inch to give the leveling effect of the fluid mortar until it cures. It also allows workability to make adjustments during the fluid state of the mortar. How you do yours is your choice.
- Apr 2015
- 104
January 20th, 2016 01:18 PM #615Ung mortar na sinasabi jan ay ung tile adhesive na mismo (kung tile adhesive ang gamit mo) na nilalatag sa concrete base o substrate. Habang basa nilalatag na rin ang tile para ma iadjust mo ung level at squareness nya. Kaya nga sa pag buhos pa lang dapat nasa tamang level na ung flooring mo. Kung hindi, mag concrete toping ka, which is kailangan mo ng cement at sand material na madadagdag sa budget mo.
- Jan 2016
- 3
January 20th, 2016 04:02 PM #616salamat po sa mga inputs nyo sa BOM.. i'll check it to our contractor.
bale ang contract po kc namin is fix per square meter. sila na bahala sa lahat from start, materials, labor, up to finishing. So ang main concern ko po is kung tama ung mga sizes at dimension na nakaspecifiy sa BOM kaya malaking tulong po yung mga inputs nyo para mai-clarify ko habang maaga at mapapalitan kung sub-standard. May nabasa rin kc ako sa ibang thread about naman sa asphalt shingles roofing na dapat 3/4" daw ang thickness ng marine plywood and when I checked my BOM, 1/2" lang ang nakalagay so I will clarify it also.
kung meron pa po kayo additional inputs sa BOM it will help me a lot.
TIA
- Apr 2015
- 104
January 20th, 2016 05:51 PM #617^ ung 3"dia na pvc pipe sa storm drain system, kung sa downspout gagamitin okay lang yan, pero kung gagamitin na linya as area drain/ catch basin to catch basin, maliit yan baka hindi tumagal ma clog agad, ideal at least 6" dia kahit ung PE pipe lang.
At pag ganyan ang usapan nyo sa kontrata, siguraduhin mo na di ka titipirin sa materyales ng conttractor mo.
- Jan 2016
- 3
January 21st, 2016 08:41 PM #619
Everthing boils down to how good and meticulous the person who is doing the actual job and the quality of materials. There are a lot of inferior/fake materials nowadays. Just visit everyday.
- 3,754
May 25th, 2017 05:01 PM #620I think this is the most updated Thread (re posting here)
This is my problem now, I decided to build my retirement house masakit sa ulo sa pag pili pa lang ng contractor medyo mahirap mag decide at ayoko magkamali sa pipiliin ko, here are some of my questions
is 19k to 20K/sqm reasonable price elegant finish
Who should pay for Vat i got a proposal from one of the contractor and I don't know what to reply yet since Im not sure if the VAT should be shoulder by me or by Contractor? (please help its very important matter right now can't find it on the web)
While a bit of a looker, it's not useful enough for other purposes outside of point a to point b...
VinFast VF 3
