Results 631 to 640 of 808
June 12th, 2023 01:53 PM #631
Kung sa dirty kitchen yan, huwag ka na mag Granite, all stainless na lang from counter to back splash then open na lang yun ilalim huwag ka na mag cabinet.
- Nov 2017
- 289
June 12th, 2023 02:47 PM #633I prefer the undermount design, clean look. Kailangan maayos yung mag install.
Sa condo nung pinagawa ko which was done back in 2014, wala naman problema. 2 yrs ago sa vacation haus, same undermount design.
June 12th, 2023 04:39 PM #634
Long stopped using wood-based carcases for wet area sub-counter carcasses. Had enough of water & wood-borer troubles. Though pricier, PVC is prettier & lighter than cement board. Concrete? Durable but will be unsanitary once leaks occur...often unnoticed & undectected.
Sinks? Undermount comes 2nd only to integral. There shouldn't be a 3rd choice.
Some other points:
-The most common water ingress point is the faucet base. From usage(constant neck oscillation), the hard-to-reach lock nut under can loosen. A dab of PU seal on the faucet base & some Loctite on that nut will help lengthen the check interval. Keep a sink faucet wrench handy.
-Avoid pull-down gooseneck faucets on nonFull-SS kitchens. Residual nozzle water can trickle down the retractable hose.
-Keep the undersink module clutter-free, not just to avoid inadvertent hits on the P/bottle trap & lines, but also for easier leak inspection.
-Steer clear of in-cab trash bins & grease traps. Not only would these stress & age the carcase system prematurely, upkeep will be tedious & messy.
-Seal the carcase-wall joints w/ PU seal prior to counter install.
-Best to opt for joint-free tops w/ integral backsplashes like stainless. Solid surface 2nd. Granite, quartz & the like? Water will eventually compromise the slab/splashboard seams & joints. Great for looks, luxury & bragging, but aren't the most durable & practical.
Remember, cabinets will only be as good the the top you opt. Think of it as roof & house.
Hope these humble learnt 2cents are of help.[emoji120]
Sent from my SM-S901E using Tsikot Forums mobile app
June 12th, 2023 05:37 PM #635
Same sa dirty kitchen namin, no cabinets at open ang ilalim. We just use the cheapest materials (tiles) Sino ba yung nagsabi sa board na ayaw niya ng all stainless kasi mukhang morgue? hahaha! I also don't like it
What's your preference then?
- 54,211
June 12th, 2023 05:43 PM #636
June 12th, 2023 05:47 PM #637
if you go for granite, it should be one large piece to avoid gaps and the backsplash can be sufficiently sealed.
There are also large 20mm thick tiles in the market that can be used as countertops, but the corner terminations wont be as nice.
Stainless Steel dirty kitchens are fine if the owner never uses them hahaha
June 12th, 2023 06:29 PM #638
You can custom fab stainless top w/ integral sink+backsplash & use other media(wood, HPL, acrylic, glass, etc) for the cab faces. Function & form can go together.
- 54,211
June 12th, 2023 06:48 PM #639whatever happened to those porcelain-surfaced (porcelain-enameled) metal sinks of olde?
the one with a sink at the center, and drainboards on either side.
that's the style i want.Last edited by dr. d; June 12th, 2023 at 06:55 PM.
June 12th, 2023 07:08 PM #640
Kohler has an updated line of undermount enameled cast iron farmhouse sinks. Timeless. Pricey.[emoji4]
Bat pa i-share rito personally kung wala pala siyang credibility dahil lang sa pinapanigan niya?...
The Toyota Fortuner has landed (fortuner pics at...
