Page 59 of 81 FirstFirst ... 94955565758596061626369 ... LastLast
Results 581 to 590 of 808
    #581
    Yes, per butas but usually that price means he will lay down all the wires, pipes etc. as in full lay out ng electrical system ng under construction na bahay. Pag simple palit lang ng outlet or switch much much less because pwede palitan ang isa in 10 minutes or less. let's say na 15 minutes na, so 4 in 1 hour, in 8 hours, that's 32 outlets. No one's going to pay 9300 kesos for that hehe. I would give it to him for 1000 lahat na. That's generous na given na hindi kailangan electrician ang magpalit nyan. But still better to get an electrician just in case things pop up that only an electrician can solve right away.
    if he's going to lay down all the wires and pipes etc, okay na yung P9300? Nginatngat daw kasi ng daga yung wiring. 2 days daw niya gagawin. 21 butas lang pala so P6300 but still I find it so steep for 2 days. Yun ba talaga ang rate? Dapat dinala ko na lang all around namin sa bahay namin sa province
    Hindi naman new house yung samin, napabayaan lang kaya inanay at dinaga. Hehe.
    Jan 2016
    #582
    Just get somebody else, kung 2 days at 1k per day ay 2k lang. If I were you, try to haggle 1.5k, usually ung mga ganyan will cut their asking by half or 3k, then you know na sinusubukan nya maka jackpot sa iyo. May ganyan na lumapit sa akin, lilinisin, put bermuda grass and stepping stones sa garden ko for 6k. I told him I'll think about it, in a few minutes he brought it down to 3k, so I got pissed and told him I'll just call him when I decide. Ending I got someone who did it for 2k.
    #583
    Wala na kami ibang kilala. Nabili na nga mga outlet and switch and wire. Naisip ko hindi ko na ipagawa [emoji35] Ang lumalabas P2625 per day tapos utang na loob pa namin na hindi niya kami sisingilin nung per day niya as worker/carpintero. Balak i on top pa yung P800 per day ata niya. Sheesh talo pa sweldo ng AM sa bangko (P3435/day) e ang haba mag lunch at aga umuwi sabi ng pinagkakatiwalaan namin
    Bakit may mga tao mapagsamantala? Hindi nila naisip hindi na uulit sa kanila.
    What do you think is a reasonable rate for those 21 butas?
    Jan 2016
    #584
    Daily rate lang ng electrician sa area pwede na. Kung matapos nya 1 day then good, if not, he will definitely finish it early on the second day. This is much better than pakyaw because he will do the work better to make it longer. Pakyaw kasi gets you a sloppy job on a much higher daily rate.
    Pero kung sya gagawa dapat same daily rate lang. Carpenter/all around tapos kung may electrical work, special rate? Baka pag tinanong mo sya kung ano maganda para sa sakit ng ulo, singilin ka ng doctor's fee [emoji23]
    #585
    Yes ganun na nga! Sabi niya electrician din daw siya but now I am starting to doubt. Dapat talaga yung all around na lang namin dinala ko sa province.
    Sinabi ko rin sa driver namin, sobrang affected. LOL! Naka ilang tawag na, sana siya na lang daw gumawa. Ipatigil ko daw LOL. Tinanong niya electrician friend niya, ang sabi P3500 daw, yung cousin ko sabi P4000 pwede na.
    So tama nga yung sabi mo na tawad ng half kasi if I tawad ng P3k, mag bargain pa yun we will end up at P3500 or P4000 pa rin. Ang problema sinimulan na pala kanina yung work e wala naman kami go signal!
    Mar 2013
    #586
    Who here has a Smart home?
    Is it worth it? Or did you get sawa after a few uses? Party trick lang? Or really useful?
    What are the things to avoid?
    What are the essentials?
    And how about future proofing?
    Im thinking i need for lights but how hard is it to turn on a switch really?
    Sent from my SM-S918B using Tsikot Forums mobile app
    #587
    Too early to future-proof w/ smart systems at their infancy. You'll likely feel like an experiment & AI is coming.[emoji4] Invest in solar instead, sir.
    Sent from my SM-S901E using Tsikot Forums mobile app
    #588
    Last 2020, I constructed an annex with garage to my existing house. I used smart switches bought from Lazada for all the lights of the annex.
    It's really useful as I can automate which lights will turn on and off at certain times of the day.
    I can set zones in the app so I can turn on or off all of the lights in a certain room. And when I am away and I see in the CCTV that certain lights were left On, I can turn them off remotely.
    Signature
    Mar 2004
    #589
    [/URL]
    Party trick that will eventually wear off ... are people so lazy that they cannot make effort to turn off a switch? ... then they pay gym membership to exercise? ... If you have extra funds, it's good to have ... but personally, it's another thing to break in the future ... maybe for selected external lights for security it would be useful since you can set schedule ... it's the same with those electronic door locks ... making it easy for hackers to break-in ...
    Better to spend on the new generation of LED lights that has just one transformer / adapter ... you have one central unit in your ceiling / roof and the lights are connected via 12V line and not 220V per light + adapter ...
    Mar 2013
    #590
    Yes I think at most will do like boybi for lighting (exterior) and invest the rest in Solar .
    But i wont do those remote controlled curtains, thermostat, etc.
    What is a decent cctv system that u can access on your phone without needing static IP?
House Construction
