Page 10 of 41 FirstFirst ... 6789101112131420 ... LastLast
Results 181 to 200 of 809
    Jun 2015
    #181
    Papano i-waterproof ang isang wall na pintado na?
    Sa mga howto videos na napanuod ko kasi yung Plexibond hinahalo dapat sa semento bago itapal sa pader. Yung ibang pang-waterproof din kailangan i-scrape off yung lumang paint bago i-apply. Eh itong pader namin kasi hindi kininis kaya parang mahirap yatang ma-scrape off ang lumang pintura. O kaya pa rin bang tanggalin ang pintura sa hindi makinis na wall para mapahiran ng pang-waterproof? Ano ang magandang gamiting pang waterproof?
    Ano pa ang ibang paraan? Ang pintura kasi sa loob ng bahay nagkakaroon ng parang mapa. Akala namin sablay lang ang pagkakapintura pero recently may nakita kaming crack sa finishing na may tumutulong konting tubig pag matagal na umuulan.
    Isa pang tanong should I be worried sa structural integrity ng pader na ito?
    #182
    decades ago,
    our newly-built house had a firewall that refused to stop leaking during not-light rains..
    we tried everything.
    finally, in disgust, dad applied flat galvanized sheets over much of the wall, from the outside.
    that fixed it. until now, over 40 years na, it still hasn't leaked.
    now where's my wood? i better knock on it...
    #183
    decades ago,
    This is how we do firewalls, doc. Viewed from the neighbor's side. No cracks, no painting needed, no leaks.
    Jun 2015
    #184
    Nasa magkano kaya paganyan? And do i have to do the whole wall? O top half lang ok na?
    Sent from my Nokia 6.1 using Tapatalk
    #185
    that looks nice.
    that technology wasn't yet easily available locally, back in the day.
    we made do with flat, non-corrugated GI sheets, the one traditionally used for kulahans back then.
    parang linagyan namin ng vertical bubong yung firewall. from the top, to within a meter or two from the soil below.
    #186
    Parang nasira naman yung vista ng neighbor
    Mukhang warehouse.
    No choice ka kailagan several coats ng waterproofing rain or shine meron sila yun ordinary pero meron di sila yun mas malapot for unfinish wall.
    But you have to do it religiously as part of your house maintenance. I do it yearly.
    #189
    it's a more photogenic picture than the black firewall of olde.
    besides,
    chances are,
    the neighbor has one exactly like it.
    but the building code or subdivision rules should have rules to regulate these.
    #190
    besides,
    chances are,
    Diba ideally dapat may distance ang house from the bakod
    Jan 2008
    #191
    minimum of 2 meters yata.. pag less than 2 meters, need mo na mag firewall na lagpas dapat yung wall sa edge nung roof.
    Jan 2016
    #192
    Contractor wants to adjust the stand offs (button attachments) by filling the hole with cement and reboring thereabouts again. Is this strong enough? I was thinking, rebore a bigger hole, lagyan Ng kalso to fix the standoff and insert epoxy? Need your advice please [emoji120]img_20200820_123357.jpg
    Jan 2016
    #193
    If it's possible to use a power sprayer on the wall, that would be sufficient to remove loose paint and debris, then you can apply plexibond 2 coats, which is ideal, while the surface is wet. Then 2 more coats Boysen Acrytex, that's what I did. As Shadow says, maintenance with Acrytex or similar paints.
    Edit: plexibond on wet surface pala applies when it is bare pa, ask na lang the paint experts if this is also the case with painted surfaces.
    #194
    Whole wall, sir.
    #195
    Consult HILTI or Fischer, sir. They have specific compounds for that purpose.
    #196
    Clad it, sir. 1 go perma-solution. Cementitious, elastomeric, even membrane layers would require periodic stripping & reapplication.
    #197
    That should be okay if limited, - in our village's case up to 6 meters only.... Not the whole side...
    Ang sama talaga ng itsura. Parang bodega.
    #199
    We hear you bro....😃😁
    Kaya dapat magusap magkapitbahay na same side firewall nila...😎
    #200
    It's that or recurring water problems. That angle isn't public....a neighbor exclusive.[emoji4]
    You can spend more if you wanna play the adjacent guy's moolah'd Samaritan & use aluminum cladding instead.[emoji4]
House Construction
