Results 191 to 200 of 908
July 19th, 2010 09:49 AM #191
paano niyo ginagamit gen set niyo? tuloy-tuloy hanggang maubos na gas then karga na lang ulit? or meron set time then off niyo muna?
July 19th, 2010 10:13 AM #192
as far as what we use is concerned, habang umaandar, pag mababa na ang fuel level, there will be a warning sound
so karga na dapat bago maubusan
sa mga generator na walang warning sound, dapat bantayan ang fuel level
pag mababa na, magkarga
July 19th, 2010 10:28 AM #193
- Aug 2003
- 9,720
July 19th, 2010 11:41 AM #194thanks for the replies.
maiba naman ako konti...advisable ba to make a small bahay bahay for the genset, with around 2 to 3 -foot elevation? What would a typical one be made of? i would assume the base would be made of wood or any similar material that can deal with vibration.
Any chance na mag overheat siya due to inadequate ventilation?
July 19th, 2010 12:13 PM #195
I'm assuming na mas mahal yung mga sound-proof at diesel na generator, but can you give me an idea kung mga magkano kaya yun?
July 19th, 2010 12:50 PM #196
July 19th, 2010 12:57 PM #197
July 19th, 2010 01:09 PM #198
^^^ It is rated at 3KVA, Honda genset, gasoline fuel.
Load is about 120W of lighting, a refrigerator, 2/5 electric fans for about 12/8 hours, 1HP of (water) pressure pump (kicked in about 5-6 times during the 12-hr period), TV for about 3 hours.... Bought this genset about a decade ago... Still works okay for my 'brownout' setup....
10.4K:shazam:
10.4K:
July 19th, 2010 01:28 PM #199
We used to have one during the Cory days (diesel fed good enough to run a few TV's and electric fans pero no air-con liit lang kasi) tapos around the end of the Ramos days where brownouts were rarer binenta na. Until now wala pa rin kami...
July 19th, 2010 03:13 PM #200
question, paano niyo plug yun wire ng gen set sa MTS niyo? ganito kasi s akin meron outlet ng pareho sa A/C kaso natatakot ako baka masunog pag matagal naka on. never ko pa na try ng more than 5 hrs straight na open yun gen set namin eh
para mapaayos ko na kung hinde recommended ganitoLast edited by shadow; July 19th, 2010 at 03:23 PM.
Audi abandons all-EV plan; gas powered cars to continue after 2033 | Autoindustriya...
Audi will no longer develop new...
