Results 1 to 10 of 23
- Dec 2015
- 29
February 7th, 2017 12:08 PM #1What would be the minimum battery voltage needed to start the engine?
I have a 02 Crosswind XTO
Sent using Tapatalk
- May 2006
- 1,668
February 9th, 2017 02:56 AM #29V. Pero hirap na sya. I replaced battery after.
Sa 10V, its a few weeks left. Assuming usual first start... Not multiple straight starts
- May 2006
- 1,668
February 9th, 2017 11:38 PM #4Nastart ko pa at 9V. Pero may dasal na kasama. Hahahaha!
- Jul 2016
- 939
February 9th, 2017 11:49 PM #5
February 10th, 2017 12:45 AM #6
February 10th, 2017 02:12 PM #7
pero sa naranasan ko minsan e 11.5 volts hindi na kaya...different car brand though. after chinarge ng 8 hrs ayun ok uli. sabagay beyond the service life na yung battery kaya pinalitan din few days after charging.
- Aug 2012
- 2,767
February 10th, 2017 03:55 PM #89V while cranking is okay. Normal na bumaba ang voltage during cranking.
9V at rest (not cranking) is already dead battery. 10.5V is 0% charged.
Sent from my D5833 using Tapatalk
February 10th, 2017 05:27 PM #9
Kaya pa ba madala sa digital charger ang pag charge ng mga naka 9v na batt para bumalik sa optimum or satisfactory condition?
to be or not to be, that always confuses me!
February 10th, 2017 05:53 PM #10
It's not voltage that determines whether you can start the car, but it's the starter's ability to deliver amperage. A volt meter will only give you a rough idea of the state of charge assuming that the battery is known to be in good condition. An average car batt produces roughly 400 to 500A to start the car. Assume the car batt is 9V while cracking but the ampere is only 70 so di pa rin mag-start ito
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
