Results 1 to 20 of 23
    Dec 2015
    What would be the minimum battery voltage needed to start the engine?
    I have a 02 Crosswind XTO
    Sent using Tapatalk
    9V. Pero hirap na sya. I replaced battery after.
    Sa 10V, its a few weeks left. Assuming usual first start... Not multiple straight starts
    Quote Originally Posted by istan View Post
    diba * 9v tulak na ito diba ^_^
    Nastart ko pa at 9V. Pero may dasal na kasama. Hahahaha!
    Quote Originally Posted by Janemar View Post
    Depende sa starter motor, cabling at compression ratio at number of cylinders...
    Pero usually 8.5v pataas kaya pa.
    i see, sakin pala naalala ko pag ON ko ng auto eh totally wala na umilaw sa dash. pero nakuha pa sa tulak ^_^
    May 2009
    pero sa naranasan ko minsan e 11.5 volts hindi na kaya...different car brand though. after chinarge ng 8 hrs ayun ok uli. sabagay beyond the service life na yung battery kaya pinalitan din few days after charging.
    Jul 2016
    Quote Originally Posted by XwindXTO View Post
    Sent using Tapatalk
    Aug 2012
    9V while cranking is okay. Normal na bumaba ang voltage during cranking.
    9V at rest (not cranking) is already dead battery. 10.5V is 0% charged.
    Sent from my D5833 using Tapatalk
    Sep 2013
    It's not voltage that determines whether you can start the car, but it's the starter's ability to deliver amperage. A volt meter will only give you a rough idea of the state of charge assuming that the battery is known to be in good condition. An average car batt produces roughly 400 to 500A to start the car. Assume the car batt is 9V while cracking but the ampere is only 70 so di pa rin mag-start ito
    Aug 2012
    Quote Originally Posted by kimbon View Post
    So how do you measure the remaining amperes of your battery? Para alam mo kung magstart pa engine?
    Aug 2012
    *double post*
    Sep 2013
    use the ampere meter
    Aug 2012
    Ampere meter is not easy to use on car battery. Whereas a voltmeter, you just connect in parallel sa terminals. Basta 12V and above, I am good to go. One click start. Never pa ko nagmeasure ng amperes ng battery.
    Kaya pa ba madala sa digital charger ang pag charge ng mga naka 9v na batt para bumalik sa optimum or satisfactory condition?
    to be or not to be, that always confuses me!
    Aug 2012
    Depends sa age ng battery. If too old, baka hindi na maghold ng charge. You will charge today, pero drained ulit the next day. If you have battery charger, use it. No harm in trying.
    Aug 2012
    I have a 400Amps AC-DC digital clamp meter but I have not used it for car battery yet.
    Ito lang ginagamit ko. In-car voltmeter.
    Engine Off - 12.6V (Battery OK - Fully Charged)
    Engine On - 14.5V (Alternator OK - Battery Charging)
    Sep 2013
    iba yung saken. mine is digital handheld clamp meter multimeter with probes. if mahanap ko sa bodega i post ko.
    Nov 2014
    ^ I use the same voltmeter that *red_one posted. Seems accurate naman, same reading with the handheld clamp type meter used by the casa when I had my car serviced last weekend.
    Sep 2013
    Quote Originally Posted by kai s. View Post
    sis, both gadgets should be the same reading otherwise either one is not "telling the truth" hehe
    Jul 2013
    The best way to test a car battery is to use a battery tester, used in batt charging shops. It has a clip for the negative terminal and a sharp probe for the pos terminal. Just clip to the neg pole and the pointed probe on the pos terminal. No guesswork. Can be used for 6v or 12v. It measures
    the actual current capacity of the batt. thru a low ohmage-high power resistor. Voltage readings can sometimes be deceiving.
Minimum battery voltage
