Page 49 of 73 FirstFirst ... 3945464748495051525359 ... LastLast
Results 961 to 980 of 1445
    Apr 2011
    #961
    Quote Originally Posted by POPPIX View Post
    Ang sabi nila sa akin, kung hindi pa napalitan e libre daw yung 4 na injector
    sir, pag hinid pa sira yung solinoid ng injector asked them if they can replaced the nozzle and the o rings...
    tight budget pa kasi ako so the mechanic did replaced the two defective fuel injector and the other two they replaced the injector nozzle and o rings and changed also the injector harness.... so far mas ok na yung performance trooper...
    i have another sensor problem which is faulty RPCV hindi na accurate lagpas na sa tamang rating binigay na signal.... the casa told me it cost almost 15thou....hanap muna ako ng mas mura.. another hefty bill on my pocket......
    #962
    Quote Originally Posted by asher25 View Post
    sir sa casa mo ba pinapagawa trooper mo? hindi ba libre pagpalit ng injector?
    sa RPCV sir try to go to jayson's its only 8000 pesos sa casa i think its around 12500-13000 kung malayo ka sa manila try to contact jayson's then pre arrange nyo order thru delivery LBC yata para no need to go to manila......na tech 2 ba ride mo kaya nasabi nilang sira rpcv...
    Sep 2005
    #963
    mga sir ask ko lang ang isuzu trooper skyroof edition CBU ba ito from japan or locally built? thanx
    Apr 2011
    #964
    Quote Originally Posted by dh0n View Post
    sir sa casa mo ba pinapagawa trooper mo? hindi ba libre pagpalit ng injector?sa CASA din...hindi na daw libre ang paplit ng injector tpos na daw yung campaign of free injector change... kaya hindi na ako nag insist sa libreng palit ng injector...at isa pa hindi CASA maintained first owner..la nga record ni isa.....sayang nga sana nakatipid ako kong libre
    yups!!!after they replaced the injector and test the ride they noticed that the engine is having an abnormal shaking kaya diagnose ulit yung nakita sa tech 2 na rpcv ang sira... andoon din ako ng mag diagnosed yung mechanic... no more doubt...
    kelan mo ba pinalitan yung injector mo? namatayan ka ba ng engine?or nag fuel knock?
    Feb 2005
    #965
    Quote Originally Posted by BRIAN View Post
    SKD (Semi-Knock Down) Local rims/tires, radio, aircon system, tirecover and front chin.
    Sep 2005
    #966
    Quote Originally Posted by Benzmizer View Post
    may front chin ba? wala naman kasama. may vintag pala siya sa passenger side door.yun aircon system ano brand locally?
    Feb 2005
    #967
    Yes, may front chin yung last batch of Troopers released (like mine). As for the aircon system, SANDEN gamit.
    Sep 2005
    #968
    sir isuzu trooper skyroof din sayo? can you post picture ng chin? and nag foglights ka ba? ano gamit niyo po?
    Sep 2005
    #969
    sir can you post the pic of chin? and nag foglights po ba kayo? ano po ginamit niyo oem or hella
    Feb 2005
    #970
    Yes, my Trooper has standard (OEM) foglamps. I believe they are Hella.
    Sep 2005
    #971
    thanx iba papala ang grille namin ng skyroof 2003 model....what model is yours?
    Feb 2005
    #972
    2005. If your grille is that with the billet-type, you need not have to replace the grille assy itself. You just need to remove the billet for it's just screwed on top of the grille you see in the photo.
    Sep 2005
    #973
    ah ok mas late model pala yan ganyan na grille i thought mas luma....yes billet type sa amin ang pangit!
    so isuzu emblem na lang need bilhin?
    Sep 2010
    #974
    Mga Tooper Gurus,
    Tanong ko lang po ulit, pag faulty ba ang injector, talaga po bang hindi iilaw ang CHECK ENGINE indicator?
    Salamat,
    POPPIX
    Apr 2011
    #975
    POPPIXMga Tooper Gurus,
    [COLOR="#000000"]based on my experience hindi po iilaw ung check engine.....symptonsa think are power loss, fuel knock lang at parang mamatayan ka ng engine....[/COLOR]
    Feb 2005
    #976
    Correct!
    Mga Tooper Gurus,
    Salamat,
    POPPIX
    Nope, it doesn't. Another indicator would be the unstable (flickering) RPM needle. Normal should have it peg solid to 800rpm.
    Sep 2010
    #977
    Salamat po Sir, panong power loss, mahina po ba ang hatak?
    Sep 2010
    #978
    Correct!
    Salamat po Sir, Kasabay po b ito ng powerloss or it may or may not be at the same time?
    May epekto po ba sa hatak kung madumi ang air filter? salamat po
    Feb 2005
    #979
    Pwede. But based on experience and testimonials, madami rin ibang factors/symptoms that may result to this. Best pa din ipa-Tech 2 mo Trooper mo.
    Yes, may epekto kapag ubod na ng dumi ng air filter. Parang masasakal kasi takbo nun.
    Sep 2010
    #980
    Salmat po Sir,
    Try ko po mag pa tech II bago mag long week end..
    Long week end kasi means long drive.
    Salamat po ulit
Isuzu Trooper discussion
