Page 48 of 73 FirstFirst ... 3844454647484950515258 ... LastLast
Results 941 to 960 of 1445
    Feb 2005
    #941
    Quote Originally Posted by dh0n View Post
    thanks sir bob...
    the tech 2 reads nothing(i mean no fault)...but the RPS reading is still low, lowest at cold cranking 3.9mpa the required is atleast 3-5mpa..
    Really? Why did it work for me? IMHO, it's the mechanic attending to your Trooper/using the Tech 2 who reads nothing. The Tech 2 gadget, when used by a qualified technician, should be able to point, if not determine, the problem.
    My 2 cents.
    Sep 2005
    #942
    *benzmizer sir bob ikaw pala yan kamusta? hindi mo na kukunin sev marchal? hehe
    where to buy orig oem switch ng foglights for isuzu 2003 skyroof?
    sa jayson kasi yun foglights nila wala kasama na switch
    Read more: http://tsikot.com/forums/isuzu-cars-...#ixzz1Z5YMrgKO
    Sep 2005
    #943
    Quote Originally Posted by POPPIX View Post
    Mga Trooper Gurus,
    Ano po ba ang maganda sukat ng mags kung sakaling magpapalit ako. May epekto po ba ito sa FC ko. mag kano po ba ang difference sa presyo ng mga goma?
    Salamat,
    POPPIX
    gusto ko sana ilipat itong mags sa trooper namin same kaya sila specs ng montero? currently installed sa montero kasi namin
    18x8 +20 offset 265/60/18
    #944
    got my trooper back last friday (6 days din sa casa)ayun na ayos din...
    injector harness and rps connector is the culprit...DAW!?
    pansin kulang parang umingay engine, sabi sa casa same lang DAW and the engine oil light lit about 2more seconds after start up ...
    due din siya this month for registration renewal another 4K blow...
    Sep 2005
    #945
    ano brand ng oem fogs for isuzu trooper skyroof edition?
    #946
    Quote Originally Posted by BRIAN View Post
    Hella Comet ata bro..
    Sep 2005
    #947
    nakita ko sa walco kanina is stanley eh...
    to all isuzu trooper skyroof edition owners i have a problem....diba pag naka start ang engine then you open the doors nag blink yun
    both signal lights? sa akin wala na kahapon lang...pero still may sound pa din ng signal light at the instrumental gauge ano kaya problem? and diba pag nag on/off ka ng alarm dapat yun signal light or parklight umiilaw? pero sa amin wala na din ano kaya problem? lahat
    yesterday lang talaga lahat nangyari.
    #948
    Baka nga Stanley
    Bosch Aux lights kasi naka-kabit sa Trooper ko before.
    Baka may loose connection lang sa module ng alarm system ng Trooper mo, meron parin naman sound pag lock / unlock?
    Sep 2005
    #949
    *starexgold meron pa din sound nawala lang yun blinking ng light on/off ng alarm ano kaya problem doon sa pag open door hindi na umiilaw yun mga signal lights
    Jul 2003
    #950
    Brian, check mo yung wire sa right door mo kung saan nakaconnect yung alarm madalas doon kinokonnect ng installer ng alarm. Better ipacheck mo sa installer ng alarm para ma isolate yung problem.
    Sep 2010
    #951
    Mga Trooper Gurus,
    Nadito ako ngayon sa CASA sira na daw ung injector one ko.
    35k daw ang isa, di palang sigurado kung kasama pa ung trooper ko sa warranty kasi baka daw napalitan na.
    may chance b na hindi pa ito sira, "is second opinion needed" o ito na talaga
    salamat
    POPPIX
    Feb 2005
    #952
    Mga Trooper Gurus,
    salamat
    POPPIX
    It's likely an accurate finding but you may still a chance to be included in the campaign. Guys from the CASA should know this.
    Apr 2011
    #953
    another victim of the 4jx1 injector problem...
    POPX same problem ata tayo........posible pa kayang mainclude patayo sa recall nitong injector hindi pa kasi napilatan ito.....
    VIN number start at UBR73...
    pina check ko sa CASA Iloilo yung trooper namin kanina because of low ilde and slow pick of rpm yung start up and stronger engine vibration that not present nor i felt before... and they diagnosed it wiht tech 2 and it turns out that the injector 1 and 3 is sira... so after 75 thou km bumigay na nga yung injector...
    very expensive yung injector it cost 160 thousand daw!!!!sabi ng isang SA... ang cost isa ng 4jg2 engine....
    tanong ko sa mga master.... pwede ba na dalawa lang yung papalitan? kailangan na same euro2 or 3? at saka same serial number?
    or the 1 set of injector is needed?
    Apr 2011
    #954
    sir, kamusta na ang trooper nio?
    Sep 2005
    #955
    solve my problem na....sa alarm module lang pala may sira na isang diode and relay that's it
    #956
    Quote Originally Posted by asher25 View Post
    since nakuha ko ok na siya...no problem so far...
    san casa ka nagpapagawa? kung injector problem mo try to ask jaysons auto supply for the price mas mura keysa sa casa...
    Jun 2006
    #957
    good thing is my trooper has 4jg2 engine. no problem yet, nearing 200k on her mileage same pull same grunt. no signs of oil drips on cylinder head and oil pan. feeling bad for 4JX1 owners. from a bulletproof engine to a lemon engine. huh.
    Sep 2010
    #958
    Quote Originally Posted by Benzmizer View Post
    Salamat Sir Benz,
    Talaga po bang hindi iilaw ang CHECK ENGINE indicator kung may tama ang injector.
    Salamat,
    POPPIX
    Sep 2010
    #959
    Ang sabi nila sa akin, kung hindi pa napalitan e libre daw yung 4 na injector
    Sep 2005
    #960
    yup libre nga dapat kung hindi mo pa pinapalit sa iba....like sa amin 4jx1 sa isuzu casa namin pinagawa kaya libre.
Isuzu Trooper discussion
