Results 571 to 580 of 640
- May 2011
- 4
May 17th, 2011 11:54 PM #571newbie lang dito sa tsikot pero matagal na rin ako sa ibang auto-related forums.
tanong lang bago kasi ako sa diesel na sasakyan, isuzu xuv 2010 model yung sa akin. nkaka 18k KMS. na rin yung auto. kailan ba kailangan palitan ang tranmission oil tska gear/axle oil ( sa ilalim ng sasakyan at likod na gulong parte)? salamat!
isa pa, H7 bulb ba talaga yung bulb sa low beam (projector) headlight nito? salamat ulit!
May 18th, 2011 07:51 AM #572
- Jun 2011
- 5
June 25th, 2011 01:43 PM #573Sir Benzmizer, would you know where I could get a bumper overrider for my XUV 2002? My cp# is 09214920300. Thanks in advance
- Jan 2009
- 3
July 3rd, 2011 05:15 AM #574sir benz, how will i know if yung ingay under the hood is galing sa fanbelt or bearings, may squeaking sound kasi na paputol-putol nangyayari ito coming from a long off ng makina then pag start ko yun may sound sya pero nawawala after a while. thanks in advance.
- Jan 2011
- 193
July 3rd, 2011 12:11 PM #575I am translating and my tagalog is very, very rough - Sorry!
A broken or cracked fan belt will usually give a "rapping" sound more like a very fast knock.
A loose, worn or misaligned belt will usually "squeal" as you rev up the engine. To temporarily remove the squeal rub a bar of soap on the side of the belt - but NOT when it is running!
When the bearings are loose, you can usually move the fan from side to side and feel the looseness.
Let us know your findings so that my very good friend Sir Benz will be better able to advise you.
Ciao!
Uncle Nick.
- Jan 2009
- 3
July 3rd, 2011 02:38 PM #576uncle nick, pina check ko kanina yung mga fanbelt medyo loose nga daw, then they remove it to check if may mga cracks so far in good condition pa sya they made some adjusment, nawala yung sound pero try to check it later after a long off., sir tanung ko lang just in case i need to buy a replacement for this san ba nakakabili ng katulad sa isuzu, medyo mahal sa casa at 1300 each, and 800 yun maliit. thanks for the advise ng pala.
July 5th, 2011 07:56 PM #577
hello isuzu pips,
how much is the throttle valve cable (labor cost included) as well as the other necessary service (ATF replacement, oil pan gasket & filter) for the automatic tranny of sportivo?
hoping for replies asap.
TIA
July 6th, 2011 10:46 AM #578
- Sep 2010
- 129
July 6th, 2011 09:09 PM #579The 2 parallel large fanbelts of my Sportivo '05 show different tightness when hand-pressed/checked.
Is there any problem with this mga Sirs?
How can they be adjusted - there seems to be no independent tensioners for each of them??
TIA
- Jan 2011
- 193
July 7th, 2011 08:34 PM #580It is not good because most of the stress is placed on one belt (the tight one) rather than two as originally designed.
The belts should be replaced in pairs with identical (manufacturers) belts.
As a tip; In an emergency, if your belts fail, a temporary repair is to "make" a belt using panty hose.
This would be a test of your negotiation skills; i.e. to convince the closest lady to give you her panty hose!!
Ciao!
Uncle Nick.
Oh, no....I didn't know there were casualties. So sorry about that. Ramon Ang said he will...
