Results 531 to 540 of 640
July 6th, 2010 12:42 PM #532
July 6th, 2010 12:58 PM #533
Hehehe sensya na medyo vague yata tanong ko, ano ba mga maintenance ang dapat gawin sa Crosswind say at 60k Kms at 80k Km and 100k Kms.
Ano ba mga dapat i-check kada 20k kms?, gusto ko kasi pacheck ung suspension system ko kung may kailangan ng gawin. The best parin kasi yung preventive maintenance, just want to make sure that everything is A - Okay.
July 8th, 2010 10:49 PM #534
bros ask ko lang if ever napapnsin ninyo na every 5k is parang humihina ang hatak ng sportivo?
oil used is igmo na sae40, chnage oil every 4k, ride mostly used in highway -province, napapansin ko lang kasi every time na malapit nang mag pa chnage oil parang humihina hatak at acceleration...
have anyone experienced this too?
tia
July 8th, 2010 11:40 PM #535
If sa CASA gagawin, they have a checklist that they follow --- depending on the mileage. I mean there are standards that are done every 20k, such as drain all fluids and open brakes (cleaning and checking if needs to be replaced). But on certain mileages (in 20k intervals), they perform certain checks/adjustments that you may not necessarily request but they would still perform. Should there be anything that needs to be replaced, that's the only time that they would recommend and make you decide if to replace or not.
It is for this reason that despite the obvious fact that CASAs do charge higher than mosquito shops, I still try my darn best to save up and when the time comes that I would need to have my vehicle PMS, I have enough to bring it to a CASA.
Oh, cleaning of your aircon system should be performed either every 15k or 20k.... i forgot na.
- Feb 2010
- 194
July 12th, 2010 12:58 AM #536You would need to replace:
- Front fenders (LH/RH)
- Headlights
- Radiator Grille
- Sub-Frame bracket (the one between the condenser and radiator)
- Headlight panel (the small metal part under the headlights)
July 12th, 2010 01:01 AM #537
July 12th, 2010 11:16 AM #538
- Feb 2010
- 194
July 15th, 2010 05:40 PM #539Sir Benz, there is no need to modify the bumper bracket pala. . . i saw it in the parts catalog in the other thread of Isuzu cars, part no. 84 and 30. . . looks different, but at a closer look, they're just different because the hook in newer model is a bit extended . . . thanks again. . .
- Jan 2010
- 274
July 19th, 2010 05:50 PM #540Mga Sir, tanong ko lang if anyone know of any "loss of power" issue sa 2007 crosswind xuv or crosswinds, in general, with the same engine. There are time na kapag tinapakan ko na yung accelerator, instead na humatak, parang nabibitin yung makina.
TIA!
ang palag ako dito eh sa gulong kasi good for 10years yan. Eh ako ilan low mileage cars ko...
[AI] Here's what they'll check during MVIS...
