Results 541 to 550 of 640
- Dec 2008
- 5
July 20th, 2010 09:55 PM #541good evening po mga sirs,
quick question ko lang po. i've recently noticed on my 2005 xuv that the distance bet. the wheel and the body cladding at the rear.. the left side is higher than the right side and i also noticed that the right side (rear) wheel is medyo papasok ung gulong sa claddingl... what could be the issue here mga sirs? hope my post makes sense :D
thanks in advance po.
- Aug 2009
- 349
July 20th, 2010 11:45 PM #542Normal ba na ma-usok (black smoke) 1st time mo e-start yung engine? (espicially in the morning...) Yes! its diesel engine but sometimes parang dina ok yung usok na lumalabas saka nakakahiya at nakakaawa naman sa mga nakaka amoy nito.
thanks!
- Nov 2006
- 103
July 28th, 2010 11:24 AM #543I need some help!
One of my warning lights started to turn on this morning. Its the one that looks like a lamp. katabi siya ng handbrake light. hindi ko kasi mahanap manual.
BTW...2003 crosswind xuv a/t sken. ano kailangan gawin sa warning lamp na yan.
Thanks in advance
July 28th, 2010 02:46 PM #544
Is the one in yellow highlight the one you are referring to?
If so, that is the WATER SEDIMENTER. It's likely that there is water/fuel mixture. You can drain the water by opening the screw under the sedimenter until you see a clear flow of fuel (diesel) coming out. Then plug back the screw.
If water is still evident, you may need to bring down your fuel tank, clean it and replace the fuel tank filter.
Or, it could just be a defective sedimenter switch. Here is how to check:
Hope this helps.Last edited by Benzmizer; July 28th, 2010 at 02:51 PM.
- Nov 2006
- 103
July 29th, 2010 07:10 AM #545thats exactly the warning light that lit up yesterday. thanks for the insight. btw, where can I find this sedimenter?
thanks again
July 29th, 2010 09:42 AM #546
- Nov 2006
- 103
August 9th, 2010 12:16 AM #548
pa help naman po..ano kaya problem ng XUV ko? kapag kumakaliwa ako na naka full Steer (sagad manibela) ko the left may lamalagatok sa ilalim..ano kaya to? has anyone experienced the same problem? Pls help, san ko pwede ipa chaeck to? pero pag pakanan wala naman.
- Mar 2010
- 143
September 19th, 2010 06:59 PM #549Experienced this several time while driving on heavy rain: bakit yung water splash napunta windshield at hindi sa sideways (tulad ng ibang kotse)? Instant zero visibility kasi at delikado kapag medyo mabilis at di napansin na may water puddles sa daan.
September 19th, 2010 09:26 PM #550
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
