Results 471 to 480 of 640
- Jun 2010
- 87
June 4th, 2010 10:01 PM #471my xwind is still on isuzu warranty, (almost 29000km) my question is pwede ko b ipa- wheel alignment ito sa labas, previous owner told me that just only two weeks ago n dinala sa casa to fix this steering problem, pero ganon p din n xpereince ko, bigla n lng kumakabig.
- Jun 2010
- 87
June 4th, 2010 10:11 PM #472my xwind is still on isuzu warranty, (almost 29000km) my question is pwede ko b ipa- wheel alignment ito sa labas, previous owner told me that just only two weeks ago n dinala sa casa to fix this steering problem, pero ganon p din n xpereince ko, bigla n lng kumakabig.
June 4th, 2010 10:41 PM #473
Hehehe! Baka sa dami ng accessories na ikinarga mo sa unit mo kaya discreetly na drain battery mo. If you didn't leave anything on and/or for no reason na-drain na lang, you better have your battery check from where ou got it para if product defect, mapapalitan while under warranty.
Now if battery is ok but just got drained, you may have to trace the electrical mods you have done on your unit. That's not a good sign.
Preferably, sa CASA mo pa rin ipa-align since it's still under warranty. The process of alignment would require (if found needed) adjustment sa ilalim. That act may be grounds to void the warranty kasi. My 2 cents.
- Jun 2010
- 87
June 4th, 2010 11:00 PM #474how much you have to pay to casa for your warranty check-up, etc. Is it free their service, as far they inform me was the only important to check from casa was only for the engine like change oil, etc., but for the other things like wheel alignment, camber, etc., they said that it more better to do a job outside casa..was it true, need help
June 5th, 2010 01:30 AM #475
June 5th, 2010 07:07 AM #476
June 5th, 2010 06:44 PM #477
if you want good qulity service wheel alignment go to bridgestone the fort. malapit sa bagong st. lukes hosp...minimum charge nila for wheel alignment is 1.2k yan ay kung walang sira ang iyong pang ilalim kasi kahit san ka pumuntang shop indi nila yan maa-align pag may sira, kailangan palitan muna. good thing there maantay mo pa sasakyan. dapat early ka pumunta kasi walang appointment dun. walk in lang lahat, first come first serve.
- Jun 2010
- 11
June 8th, 2010 05:18 PM #478pano po magpost ng pics? newbie po ako its my first time here. newbie rin po ako sa crosswind just bought a 2nd hand 2004 xuvi limited edition daw. ipakita ko sana tsaka hingi ng suggestions kung ano maganda palitan
June 8th, 2010 05:46 PM #479
June 8th, 2010 06:19 PM #480
Kung alignment lang walang problema di ma-void yung warranty. Wag ka lang mag palit ng gulong na mas malaking radius (gulong + Mags) kaysa OEM. Dati yung aking Crosswind 2 time ko pina-align sa Casa pero ganun pa rin bumabalik yung problema so pinagawa ko sa labas ayun ok ang kinalabasan di na bumalik yung problema. Minsan ung casa di sila bihasa sa ibang bagay na dapat ayusin in fact gaya pag radiator may problema dinadala pa nila sa labas para ayusin.
+1 on the Amaron. Yeah, just make sure it will fit and can be held in place securely due to...
