Page 176 of 186 FirstFirst ... 76126166172173174175176177178179180 ... LastLast
Results 3,501 to 3,520 of 3710
    Dec 2015
    #3501
    Mga sir sino na nakapagpalit ng shock absorber ng spirtivo. Ano specs ng front at rear shocks? Ano mas maganda air type o liquid type? Magkano kaya price? Maraming salamat po.
    Dec 2015
    #3502
    Reasonable na po bra ang P9,500.0 na singil ng kasa para sa 60,000km PMS? Schedule PMS bukas sa casa
    May 2009
    #3503
    Quote Originally Posted by Bhenru View Post
    nagpalit ako neto lang ng shock absorber sa likod ng fuego which is basically mechanically the same sa crosswind.
    go for the nitrogen charged shocks (gas type). mas matagal magfroth (overheat) ang oil
    KYB gas-a-just part number 553230 for the rear
    tapos 553119 or 553287 sa harap
    you still need to confirm the part numbers.
    60k kms PMS? sa labas ko na lang ipapagawa kung crosswind lang naman. hindi naman ganun kaselan ang sasakyan na iyan.
    Dec 2015
    #3504
    Quote Originally Posted by miked View Post
    Thanks sir miked sa mahalagang information.
    Jul 2016
    #3505
    Quote Originally Posted by Sleepcare View Post
    Pwede yan sir...
    Salamat sir
    Sent from my SM-J500G using Tsikot Forums mobile app
    Jan 2017
    #3506
    Isuzu crosswind XTi 2008, my gumamait nba s nyo ng Castrol manatec 10W40, okey kya sya. para kasing medyo mas maingay yung engine ngayun e,,, thanks
    Jul 2016
    #3507
    Quote Originally Posted by AndyBoy View Post
    Prone daw sa sludge ang castrol.sabi sa mga review sa net
    Jan 2011
    #3508
    Walang catalytic converter ang Xwind.
    merong cat converter ang crosswind.
    #3509
    mga sir, bat kaya bumubulwak sa dip stick ung langis?
    at ung part po na may belt ano po tawag dun? may tagas din po kasi. ano po pwede gawin?
    crosswind xt po model ng sasakyan.
    newbie lng po ako.
    Attached Thumbnails Attached Thumbnails 20170301_194621.jpg   20170301_194852.jpg   20170301_194842.jpg
    Mar 2017
    #3510
    Mga boss, baka may alam kayong shop na mabibilan ng manual side mirror and aircon louver for crosswind 2003 model, salamat in advance sa magrereply
    #3511
    Quote Originally Posted by mr.xtraordinary View Post
    newbie lng po ako.
    yung nasa belt, hydraulic fluid ng power steering yan, check mo ang hydraulic hose or yung pump niya
    Apr 2009
    #3512
    Quote Originally Posted by arveeab View Post
    anong year XT mo? yung 2001 XTO ko nagleak din hydraulic hose last year. nirerepair yan may shop na specialized sa hose pakalas mo lang yung hose. nagastos ko 750 sa replacement ng hose.
    Jul 2014
    #3513
    good eve mga sir, ano po bulb ng projector lamp ng crosswind? and pwede po ba taasan ung wattage ng bulb? and how to install it thanks
    Jul 2014
    #3514
    mga sir, san nakikta ung adjuster ng projector lamp naten? badly needed, wala kase sa owners manual ko eh, thanks
    Dec 2015
    #3515
    Good morning. Meron po ba mabibilihan ng side mirror ng Crosswind XTO sa evangelista? Kahit po surplus?
    Mar 2017
    #3516
    meron bang free na hazard triangle mga crosswind natin?
    Jan 2011
    #3517
    sino po ba ang naka experience na po ng pa rebuilt ng automatic tranny ng crosswind? magkano po inabot? sliding na talaga ang sa akin... taas na ng rpm, bagal pa ng takbo..
    Sent from my SM-G610Y using Tapatalk
    May 2017
    #3518
    Good day po!
    Share ko lang po ang experience ko with our Crosswind XUV Limited AT . After hearing a friend's recommendation, I decided to try out Shell V-Power Diesel. After some time, I noticed that I hardly see smoke coming out of my exhaust. This is specially apparent during overtaking speed when I have to press hard on the accelerator pedal (2.5k-3.5k rpm).
    For those wondering if it's worth it to pay extra for higher-grade diesel....my non-expert opinion is yes! Well, at least for our Crosswind, it is. Cheers everyone!
    May 2005
    #3519
    Hi there! It's been years since I visited this forum. Our unit is a 2004 Crosswind XTRM (Automatic). Lately, it has been experiencing problems in starting the ignition. The past 2 weeks, pag-switch, walang tunog o Redondo man lang. After 2 or 3 tries nagstart siya normally. Hanngan sa kaninang umaga, ayaw na talaga. So I called Motolite, thinking its the battery. Mag-2 years na iyong battery so covered pa ng warranty. Then kanina, chineck ng taga-Motolite malakas pa daw iyong battery and true enough nagstart siya. He also checked the alternator and ok daw ang starting. Baka daw may problema na sa wiring, possible grounded. Noong nakaalis na siya, I tried to start and again it took me two tries and it started.
    Anyone who had similar experience or idea as to what could be the source of the problem? Thanks in advance!
    Apr 2017
    #3520
    Quote Originally Posted by Tsuperman View Post
    Sharing my experience, kapag click sound lang pag turn ng key, electrical problem. Madalas battery failure. Kapag turn uli at nag redondo, contact ng wiring. Did not send power to the starter sa initial switch. Not an auto electrical expert. Sharing lang..
Isuzu Crosswind Owners Thread [continued]
