Pasingit naman mga sir,
Ano ang headlight bulb ng Crosswind 2007 XTI? H4 ba?
Salamat!
robot.sonic
Salamat!
robot.sonic
pag nagupgrade ba ng headlight from 2008 to 2010 projector type may babaguhin ba sa wiring.
Mga bro,
Pwede ba magpagawa ng bagong remote for the alarm?
Cobra alarm ko, na binili ko sa Isuzu Inteco. Originally, may dalawang remote.
Kaso nasira na yung isa. At itong gamit ko ngayon, nabibiyak narin.
Nakakapag-pagawa ba ng spare?
Thanks!![]()
sir, you might as well check your water pump. i had similar problems before, ok naman higpit ng belt pero lagi may squealing sound, after a while bumigay yung water pump, theory ko eh medyo humigpit na bearing nya kaya di na makasabay sa engine rev, kaya affected yung belt.
but have it analyzed by a competent mechanic, just to be sure..
Hello there, just acquired a '04 xtrm last month. Unfortunately, I now notice an oil leak. Otherwise everything is fine.
What could be the possible problem and remedy? How long does it usually take to repair it?
Can a regular mechanic handle it or should I bring it to casa? I also don't have a "suki" right now, can you refer me to a mechanic within Mandaluyong area.
How much does it usually cost to repair it?
TIA and sorry if there was a similar problem posted that I failed to backread.
Yes. one obvious example is the change from a pre-2010 (H4) to a 2010 (H1/H3 combo)
If your alarm is still an "OEM", try checking with an authorized dealer. They may be able to facilitate producing one thru it's original maker (local company)
Thanks sir benz and killer_eyes.
If that's the case, then I'll just contact my dealer.
Thanks guys.![]()
bro, ang "machine shop" ba andyan ba yung pressing? so sa quote na 500php para sa dalawang bushing lang yan? doon sa pinagawan ko kasi 600php para sa dalawa lang. 4 dapat yung ilalagay sakin so sa unang quote nila eh 1200php. pero okay pa naman daw yung 2 bushing ko. ganyan ba talaga ang presyo? para kasing ang mahal.
bro, nag-pa-align ako dito last saturday (servitek araneta near sm sta. mesa).
siningil nila ako ng 500php for the alignment. kala ko sa 500 kasama na yung caster adjustment. toe in/out pa lang daw yun sabi ng mekaniko. ayon sa kanya 350php kada isang side. so kung sa left and right eh tumataginting na 700php na yun?! (noted ko na kasi itong post mo so after ko sa banawe pumunta nako rito for alignment)
sabi ko nga sa bisor nila ang bilis naman nilang mag-taas eh yung tropa ko kagagaling lang dito? sabi saken presyo nila nung isang taon pa daw yung 320?
btw, (tama ba?) according sa kanila at sa ibang nag-align ng "XTO" ko. di daw applicable ang camber correction dito? as-in hindi daw puwede?
anyway, dun sa binayad ko sa servitek na 500php eh sulit na rin naman. tinest drive pa namin at nila yung ride ko hanggang sa totally ma-correct.
with regards to the caster adjustment, ginamitan na lang ni pareng mekaniko ng "magic". ayos naman ang serbisyo nila yun lang ang bilis lang ata nilang mag-taas, buti na lang nag-kasya pa yung barya-barya ko.![]()
Has anyone of you guys tried X1-R engine Treatment?...OK kaya to gamitin sa Crosswind natin? will it help boost more speed? baka sakali umabot na ako sa 120+...TIA
Its just as same as most engine treatment oil, it can help minimize engine noise because of its concentration but it will not help boost more speed... wag kn bmili nun mahal un maraming murang engine treatment, mine i used the STP brand.... If you're concern bout added boost and speed, the air intake should be modified just like most modified cars do....
Unfortunately wla pkong ganung modification na nakikita para sa mga crosswind natin,,, sana magawan nila ng design na ung air filter ay nakalabas na,,, mas mabilis ang pasok ng hangin nun and for sure it will add more speed.....
With regards to reaching 120++kph, bigyan mo lang ng tamang bwelo bawat gear... mine is xuv 03 model napapatakbo ko pa sya paminsan minsan ng 120++.....
Good Luck on your trial...
mga sir, may built in anti-theft safety features ba ang crosswind xuv LE 2010?
nakakatakot kasi qc area, tpos nabasa ko pa sa online diyaryo na
nsa top 3 ang crosswind na kinacarnap.
kung wala po anti-theft features
anu recommended niyong anti theft device?
thanks
