SOS help po mga Sirs...re my Sportivo '05 alarm system.
This AM for warm-up, i used the door keys instead of the remote. No problem with the warm-up... turned off the engine, got the keys out and closed the door. After a few steps away from the vehicle, bigla na lang nag-siren/alarm nonstop, with all the flashers blazing. Kahit anong pindutin ko sa remote, ayaw tumigil ang siren at flashers. Ayaw na rin magstart, ie no response at all from the ignition.
To silence it, i had to disconnect na lang the battery terminals. So I was forced to use my motorbike na lang pagpasok sa office.
This noon (lunchbreak), i tried to reconnect the battery. Pero, ganun pa rin talaga. Disconnect ko siren para at least hindi gaano iskandalo ang ingay...flashers na lang ang ayaw mamatay. Ayaw pa rin umistart talaga, huhuhu! Para hindi madischarge kako, disconnect ko na lang uli battery.
Help naman po...what should i do?? Hindi ko na magamit eh...
*acergy- yup baka nga reset lang yan. pero last time nung naganyan ako, weak na pala yung battery, which apparently caused the alarm to malfunction.
anyway, pasingit lang mga bro. saan ba nakakabili nung rubber para sa brake pedal. preferably pareho lang nung original,color black lang. Pareho-pareho lang ba ang mga size, if ever maghanap ako sa mga hardware? pudpod na kasi akin, kita na metal. Thanks mga bros![]()
Yeah, I totally forgot the remote transmitter. Best to check na din at baka mahina na battery kaya di na mapatay yung alarm.
Hardware? I would suggest you go to a Japanese auto supply and you may just be able to get a new piece.... worst scenario, sa surplus shop.... tiyak meron mga yun nyan.
*acergy- hmm, pero sabi mo bro ayaw magstart ng makina? I had an instance too before na weak na yung car battery then ayaw mamatay ng alarm at ayaw na magstart. Car battery pala ang problema.
*benzmizer- yup, diba meron sa mga hardware like Ace and Handyman na ganun? kaso mga de-kulay.okay thanks sir, will try to check at Fernando's tom.
ang nangyari naman sa akin bro,nag alarm din tapos ayaw mag start ng makina,yun pala sa remote lang,hehe...di ko pa kasi alam nung unang mga araw pa sa akin nung sportivo ko e...pero ok naman ang battery...
bro benz,pasingit,ok lang ba na tumagal ng 5 years yung battery ng sportivo natin..orig pa kasi yung sa akin,and sinilip ko yung fluid nya ,puno naman...ang odo ko pala ay 72+thou kms...maganda pa kasi,pero Im worried na baka bigla na lang bumigay...
Thanks Sir Benz. Kelangan pala press and hold for about 5seconds, hindi pwede press lang. Tsaka, paandarin agad once namatay yung flashings, otherwise resume siya sa flashing.
Yes, it did the trick of "killing" the alarm. Problema ko naman ngayon, paano i-activate uli si alarm??
I guess its not the car battery nor the remote transmitter battery in my case.
Pinacheck ko car battery (stock pa, 5 years old) last month, it was given an A-OK rating. Up to this time, one-click easy starting pa naman. The remote battery is only 2months old naman, at pati yung spare remote ko wont work.
Unless, either one has expired after the above-mentioned span of time...?
mga sirs is it standard in crosswind/sportivo that the spare wheel/tire is not chrome/mags?
Hmmm... Hindi ko napansin yun a, nasa casa ako kahapon pero I didn't notice that the spare tire on new vehicles now are using steel wheels instead of the sets installed. I have a 2007 XUV and its spare tire still has the alloy wheels similar to those installed. New buyers should be advised to check because the spare tire cover in current models are closed, meaning you cannot see the spare tire, unlike the 2007 version "honeycomb". Nagtaas pa naman sila ng SRP.
sportivo xmax 2010 sir jokulit,
question lang po sa tire pressure 235.70.15 yung akin isuzu recommendation is 26 front at 35 rear wheel. isnt this too soft? lagi kasi nila napapansin malambot daw gulong.
do you have any suggestion *preferred pressure for example: city driving, light load, heavy load, off road. or ano po ba tire pressure nyo na ginagamit?![]()
[SIZE=5]para sa mga isuzu owner para mas maganda yun brake natin try nyo palit rotor disc nyo naka [SIZE=7]cross drill [/SIZE]parang sa evo[/SIZE]. [SIZE=5]sa [SIZE=7]corsa auto parts[/SIZE] meron pati pang ibang sasakyan. pati mga pang ilalim.
tel:3321079/09228166080 t0 81
[/SIZE]
