Page 40 of 89 FirstFirst ... 3036373839404142434450 ... LastLast
Results 781 to 800 of 1770
    May 2009
    #781
    Nakakita nga pala ako ng Sportivo na naka 20" na mags nung Saturday, astig ng itsura!, '07 o '08 yata yun. Nagpapa-service sa Isuzu Alabang.
    Feb 2005
    #782
    Quote Originally Posted by SouthWoods View Post
    Here is one (small) photo of a Sportivo on 20" rims (pic c/o A-Toy BodyKits)
    Aug 2009
    #783
    ^ hmmm pangit para sa akin naka ganyan hehehe
    parang nagkapalda at parang di na brusko ang dating ng sportivo pag pinalitan ng 20" rim.
    Feb 2005
    #784
    Quote Originally Posted by carlmags View Post
    True. Besides, when you go DUBS, you'd have to have skirts and (a little) dropped. "Street Truck" ika nga.
    Then again, it defeats the purpose of getting a sporty Crosswind (XUV/Sportivo) di ba? Current rims with Michelin LTX 235/70R15s are good ebnough for me.
    #785
    Hi,
    Medyo off topic eto sa mga Rims, I just want to ask regarding ung shaking sa front tires when I break at 80-100kms/hr naexperience ko ito when I'm on my way back to manila, while cruising at NLEX at that speed nung nagbrake ako nararamdaman ko mdyo may shaking sa front tires ko.. I tried it again this time mdyo slower ako wala naman ako naramdaman it seems na nangyayari lang during those speed.
    Does anyone know what could be the problem? Is there any loosened bolt or I need to have my brakes adjusted? May relationship di kaya ito with may front left tire having negative camber? di pantay ung kain ng gulong medyo manipis sa inner part. I planning to bring it sa computerized wheel alignment shop, any suggestions po kung san maganda magpatrabaho nito?
    Thanks.
    Aug 2009
    #786
    Quote Originally Posted by Benzmizer View Post
    Yep nice brusko michelin tyres ...pogi looking na para sa akin hahaha
    e ganda pa ng rim...naka chrome na hehehe
    Feb 2005
    #787
    Quote Originally Posted by TholitzReloaded View Post
    Hi,
    Thanks.
    Partner, me thinks it's your [SIZE="4"]ROTOR DISCS[/SIZE]. Have them check for uneven wear.
    Camber/alignment issues would result to constant "wiggling" of front rims at certain speed... not when braking. As for a possible loose lugnut, that's easy to check. Test tighten all lugs. And a loose lug would possibly create constant wiggling but at any speed.
    There are a lot of competent camber/alignment shops. Basta computerized, ok na yun. Bottomline, have your vehicle checked ASAP.
    #788
    I think you're right Benz, I haven't replaced my front left rotor disc it already has an uneven wear on the inner part and is already due for a replacement according to the mechanic. I hope replacing the Rotor Disc solves the wiggling.. I will have it replace hopefully by end of this month before I travel back to our province.
    As for computerized wheel alignment, I think only the front left has a negative camber based on the tire wear which is on the inner part. I'll make sure to check for loose lugs.
    Thanks.
    Feb 2005
    #789
    No problem my friend. I am almost 100% sure the wiggling would be eliminated with the replacement of the rotors.
    Oh yeah, make sure you do this before embarking in any long travel. Brake system eto... considered as one of the safety items that a vehicle owner should not defer repair and compromise.
    As i usually tell myself, mas mura na ang parts and labor kesa sa buhay ko at mga kasakay ko. Makes sense, right?
    #790
    Sir benzmizer, napansin ko parang may sumisipol sa ilalim ng dashboard ko (right side) twing mag automatic yung ACU ko. pag na reach na kasi nya desired temp nya mag on/off yung thermostat nya, twing lalagatik yung thermostat nya may parang sumisipol. Kahit nung bago pa sya ganun na sya, napansin ko kagad yun. Normal ba yun? another thing, pwede ba malagyan ng HID lamp yung 08 xwind? which one do you recommend, hi beam or sa low beam lang and what brand? and ilang kelvin ba dapat? TIA
    Feb 2009
    #791
    i have the same problem narin pala nga pala dont get service sa isuzu alabang lalo ng kung sa gulong walang kwenta service dyan have it serviced at another branch.
    Baka matulad kayo sa XUV ko pag labas nagwiwiggle na sabi alignment daw at sira yung idler arm well alignment nga problema pero ang kinabit na bearing maluwag buti nalang pinaservice ko sa labas baka nakalas pa tong gulong ko.
    Yung sportivo naman namin pinaservice dun last February ayun may gas gas nakita ko lang ngayon august na tapos yung center caps naman pinalitan ng luma hanggang ngayon wala parin kapalit. Napansin ko kahapon sunday nahulog kaya ayun email ko na mga managers dun ngayon palang inorder after 7 months.
    I just hope na magimprove na ang service nila sa ngayon na pangalawang complaint ko na ito sa serbisyo nilang pulpol.
    here the concerned people pala if you decide to file a complaint. Tinabi ko pa mga email addresses.
    zalameda.ju*isuzualabang.com; concha.cf*isuzualabang.com; tenedero.eo*isuzualabang.com
    Mr. Concha Service, Ms. Zalameda Purchasing and Mr. Tenedero is the GM
    Medyo brutal ang email ko at all caps kaya di ko na popost dito awa ng Diyos dahil nabasa ng GM ayun may action agad. I told them I donīt want an apology what I want is a replacement of the center caps.
    Feb 2005
    #792
    Sir benzmizer, napansin ko parang may sumisipol sa ilalim ng dashboard ko (right side) twing mag automatic yung ACU ko. pag na reach na kasi nya desired temp nya mag on/off yung thermostat nya, twing lalagatik yung thermostat nya may parang sumisipol. Kahit nung bago pa sya ganun na sya, napansin ko kagad yun. Normal ba yun? Yes, that is normal. That sound you are hearing is a sound being emitted by the Expansion Valve for a certain period of time then it disappears --- which is located at the RH side of the dashboard (area of the glovebox)
    Another thing, pwede ba malagyan ng HID lamp yung 08 xwind? which one do you recommend, hi beam or sa low beam lang and what brand? and ilang kelvin ba dapat? Yes, you can have an HID installed in any of the Crosswind variants for that matter. I did on my '03 XUVi before. But based on some informative reads I have made, HID works "BEST" on projector headlamp-type design.
    If you are to pursue installing a set on your Crosswind, I would recommend you use Kelvin rating no more than +/- 4,500K. Anything more than this is "too white" --- proven to perform poorly on rainy, wet roads, specially on asphalt. As I would describe it, "parang naka-flashlight ka lang".
    One alternative is to install 90/100w ALL-WEATHER-type halogens (not HIDs) and use ceramic sockets.
    #793
    Thanks sir benzmizer. siguro dito na lang ako sa 2nd option mo na binigay, mukhang mas mura to.
    Feb 2005
    #794
    Quote Originally Posted by lastpogi View Post
    It is. With a budget of 2-2.5k, naka ceramic socket ka na, 90/100 bulb ka pa.
    Let us know thru this thread when you have your headlights done.
    #795
    I definitely agree with you... better safe than sorry.
    Feb 2005
    #796
    Correct.
    Guys, always bear this logic in mind whenever you are faced with the decision whether to have a concerned checked and repaired sa mga vehicles nyo.....
    "If you can afford to buy a car, then you can afford to buy parts and fuel for it."
    I am guilty (at times) to this. I would sometimes think that fixing a noisy brake would be hindrance to my plan to upgrade my sound system or my alloy wheels. But then again, i realize that what would I do with a wicked sound system or a nice chromed rims when my car is a total wreck after an accident related to a faulty brake? Moreover, would i ever appreciate them when I am a bed ridden vegetable?
    [SIZE="3"]PEACE![/SIZE]
    #797
    +100
    #798
    Hi,
    This afternoon I noticed that one of my fog light glass cover was missing, i just want to ask if anyone experienced their fog light glass cover fall off while driving. mukha naman ksi di agad un matatangal eh.. not unless may sumalbahe sa car ko while parked in front of our house.
    May nabibili kaya nun na cover lang?
    Thanks.
    Feb 2005
    #799
    Hi,
    Thanks.
    *Louie: That's odd. That's the 1st time I've heard foglamp covers of the Crosswind falling off. Me think this was intentionally done....
    As for just a cover being sold.... likely not. You may have to buy the whole foglamp piece (does not have to be a pair)....
    .... gastos na naman eto.
    #800
    Yun nga din duda ko eh.. I check the other one medyo malabo ngang matanggal sealed eh, kakaasar talga ung mga taong walang magawa.. i would have understand kung ung buong assembly ang tinangal pero glass cover lang ano naman pagagamitan nila nun?
    I inquired sa Jayson and sa Casa ang mahal pala ng OEM na foglamps 4k sa Isuzu manila, 3.5k naman sa Jayson... gastos na naman...
Isuzu Crosswind Owners Thread [ARCHIVED]
