Page 174 of 607 FirstFirst ... 74124164170171172173174175176177178184224274 ... LastLast
Results 3,461 to 3,480 of 12125
    Aug 2013
    #3461
    Quote Originally Posted by PJ Sinohin View Post
    mukhang user friendly naman kahit first time SUV & AT driver aku. though medyo matagal na sa manual na AUV.
    napilitan magbuklat ng manual para alamin paano magpalit park light and dome light bulbs - alam na kung bakit :D - matagal pa naman 1,500 PMS para ibalik ulit stock bulbs
    Paelaborate naman brod, ginawa mo bang mood light?
    Aug 2013
    #3462
    Oct 2015
    #3463
    Quote Originally Posted by Civic_Racer View Post
    hindi ko ito gets.. malabo ba yung stock?
    ok naman po yung OEM bulbs, maarte / nasanay lang sa white LED na interior lights and park lights sa ka-alternate na ride.
    Oct 2015
    #3464
    LED addict lang
    May 2008
    #3465
    http://www.topgear.com.ph/features/f...below-articles
    here's the review of the new 3.0 vgs
    May 2008
    #3466
    #3467
    Mainit yun mga lamp. Saan kayo bumili ng mga led na ipinalit nyo sa interior lights? Yun ba breaklight at saka signal lamps pinaitan mo rin ng LED? Price na rin thanks po
    Dec 2008
    #3468
    baka pa-consuelo sa atin mga naka-2.5 yung ingay ng 3.0 para no regrets :D
    Hahaha :D natawa ako dito ah ibig sabihin luma na model padin ang 3.0 na ilalagay sa bagong mu-x....ibig sabihin wala pa silang brandnew engine model para sa 3.0 ang bago is sa 2.5 4jk1 variant lang pala...:D:D:D
    Oct 2015
    #3469
    Been lurking for quite a while here, sharing what I used on my MUX interior lights. Bought from ebay.com. festoon 30mm $12 each, yung t10 $24 pair. All 4000K color temp, day and night difference sa stock halogen interior bulbs. 😉
    Left Philips LED, Right halogen
    Last edited by aar0nix; October 29th, 2015 at 12:19 AM. Reason: Pics not showing correctly
    Oct 2015
    #3470
    And replaced brakelight bulbs as well. Retained the t10 inner lights as red t10 bulbs emit a different shade of red, not the same as Rouge Red. $42 pair from ebay.com
    Led vs halogen
    Brake mode: Left philips led, right halogen. Notice how intense the light is as compared to the third brake light led
    Brake mode: Left and right philips led
    Parklights. Phonecam shows led light intensity.
    Jul 2015
    #3471
    Question lang po, yung defogger po ba ng MU X sa likod lang talaga?
    May 2015
    #3472
    Quote Originally Posted by aar0nix View Post
    Yung left philips LED sir vs. Halogen na stock?
    May nagbebenta kaya ng ganyan sir? Madali lang ba palitan?
    Oct 2015
    #3473
    Sa ebay ko nabili, pinaship ko sa kapatid ko na nasa US then dinala nya nung umuwi sya dito. Wala pa akong nakita na local seller, medyo pricey din kasi.
    Yes madali lang palitan, yung map lights sa first row, need mo lang ng thin metal ruler na kasya dun sa gilid ng lens para ma baklas yung map light. Yung 2nd and 3rd rows naman, need to take out the whole assembly same din hilahin mo lang sa gilid.
    Oct 2005
    #3474
    Guys sino nagpakabit ng TV PLUS. pati ba harap na monitor nakaka panuod? Saan controls niya?
    Oct 2015
    #3475
    Thanks for sharing the size of the cabin light. Hindi nyu sir pinalitan yung sa cargo area?
    Will try to contact Mr. Sean of "Led it Glow - fb online seller of LED sa mga car groups" if meron sya ganun sa size para sa cabin. Yung parklights palang napalitan ko.
    #3476
    Quote Originally Posted by Djerms View Post
    Being all new, I doubt if anyone can give you first hand info on the 3.0. The 2.5 tho, is a very capable suv. Torque curve is flat at 320Nm starting 1800rpm up to around 3000rpm, afterwards you still have around 280nm going down. As an owner, I can say this is believable.
    I owned a strada vgt, and I'd take the mux any time of the day because of this flat torque curve which makes it very drive-able. See, the strada vgt is only good on paper. On paper the strada makes at 178hp and 350Nm. Most do not realize that the 350Nm torque comes in very late at 3500rpm. At 2000rpm, its only making 250Nm...at 2500rpm it makes 300Nm. This makes it very anemic below 2000rpm.
    Fuel consumption is yet to be seen in actual. Cruising at 100kph, I can get 15 km/l on my Mux AT. At 80kph cruising I get 17 km/l.
    Now comparing the 3.0 and the 2.5...if you are a power freak, just get the 3.0. Im sure fuel economy will not hurt that much being an isuzu.
    HTH
    Sir, if you don't mind, may I ask how does your 2.5 MU-X perform compared to the 4D56 VGT Strada? Is it that it's very responsive even at low RPMs compared to the latter, which I heard that, despite having a VGT, it has an issue known as turbo lag, is it true? Thanks for your reply.
    #3477
    Quote Originally Posted by wonderloo View Post
    Sir, yung TV plus aandar sa front and rear monitor. If i control mo sya after nya makabit, nasa AV IN sya ng SRC. then, sa TV Plus, may sariling remote control at inilagay ng CASA sa ibaba ng front passenger na compartment. Dun sya naka mount.
    #3478
    Oct 2015
    #3479
    Pinalitan ko lahat. Kilala ko si Sean/Leditglow, meron sya nung china t10 w5w, yung festoon nya yung may adaptor na cobb led, all 6000K colorwhite.
    You need 2pcs t10 w5w size para sa front map lights , 2pcs 30mm festoon for the 2nd row, and 1pc 30mm festoon for the 3rd row.
    Here's another photo I have of the lights at night.
    Showing how it lights up the cargo area
    I used this thin metal ruler to pluck out the lens of the front map lights and the whole 2nd row/3rd row lights
    Notice how the 2nd and 3rd row lights were made by Nissan
    Oct 2015
    #3480
    hahaha uu nga Nissan!
    thanks for sharing the photos sir!
All New Isuzu MU-X // Alterra Next Generation
