Results 1 to 10 of 151
- Jan 2007
- 19
August 31st, 2007 12:05 AM #1i have a 2006 sta fe crdi. it has been going back to the casa several times in the last 6 months to correct a loud knocking sound on left front suspension. dealer said they replaced front shocks and made adjustmenys on pre load of the rack and pinion. sad to say they havent corrected it up to now. anybody else experiencing the same problems on their sta fe?
- Jan 2007
- 19
August 31st, 2007 09:18 AM #5hyundai commonwealth. in fairness to them inaasikaso naman hindi lang nila mahanap ang problema. knocking sound is on the left side only and malakas talaga. i think it really is a suspension problem thats similar to the knocking sound of the early starex models suspension. Parang mahina yata pang ilalim ng sta fe. if only this problem would be fixed, the sta fe is a damn good vehicle!
August 31st, 2007 11:33 AM #6
Can you describe further the problem?
At what speed does it happen? When turning? Even on a straight line? Braking?
August 31st, 2007 01:04 PM #7
How many times have you brought it in, exactly?
When does the knocking occur? What speed? Turning, accelerating, braking? Over what surface does it occur? Rough, smooth? Large bumps or small bumps?
Is it a rhythmic knocking that increases with speed? Is it a one-time knock that occurs over bumps?
August 31st, 2007 01:32 PM #8
Naku. naloko na.
Bakit ngayon lang to lumabas kung kailan nag-down na ako sa bangko for a Sup Red Sta Fe. puwede pa kaya ko magpa-change unit.
Tsikot Member Rank 4
- 2,719
August 31st, 2007 01:33 PM #9i don't have sta. fe ... but on our starex, the knocking noise came from the brake caliper pin, a good greasing will fix it. hth
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
