Results 7,161 to 7,170 of 7663
May 20th, 2014 07:59 PM #7161
Have it checked, manuals are supposed to be more responsive than matics, it seems you have a sliding clutch problem. Check your carpet matting also, maybe the carpet is impeding the accelerator pedals movement. I had an experience before where i had a hard time driving a grandia van. Turns out a soda can was lodged underneath the accelerator pedal.
Posted via Tsikot Mobile App
- Mar 2014
- 78
May 21st, 2014 09:20 AM #7162Sinubukan ko hanapin yung horn nung sasakyan na yan.. hindi ko makita.. parang nakatago ata sa ilalim ng bumper.. kahit ako nalang sana magkakabit.. kaya lang for the first time.. naka encounter ako ng sasakyan na nakatago yung horn... eh ayaw ko naman baklasin yung bumper.. parang ang daming tatangalin ng turnilyo
- Feb 2011
- 64
May 21st, 2014 09:31 AM #7163If i remember correctly the horn is below the headlight and to do the side of the radiator somewhat so if u wanna get to it u really have to remove the bumper unless you can put it on a lift and have the skid shield remove couldn't remember if it was the left or right and its pretty small thou. You cant compare gas vs diesel as they are 2 different kind i made the comparison base on a GL diesel tucson vs a diesel montero trust me i leave them in the dust hehe. Odd i tested my friends tucson 2.0 GLS its was pretty ok naman it shouldn't have problem getting up to speed if ur underload now i ask you what is your usually load? like full 5 people with bags etc or just you and the wife if so then there is a problem check your shifting time when your driving and see if your gear changes are high or low if its too high then bring it to the casa and have it checked btw stupid installers are a dime a dozen hence why i only bring my car to my specialist and so far all my wirings professionally done all are connected with either sockets if not are soldered on shrinkwrapped and taped with everyone also have fuses.
- Feb 2011
- 64
- Mar 2014
- 78
May 21st, 2014 02:50 PM #7165
- Feb 2011
- 64
May 21st, 2014 04:12 PM #7166nah our bumper is relatively easy to remove and bolt back on just make sure they know what they are doing and make sure all the clips and screws are in place once put back.
May 21st, 2014 05:25 PM #7167
- Feb 2011
- 64
May 21st, 2014 05:46 PM #7168can be accessed in another way but it involves raising the car in a lift and removing the front skid guard you can then access it. but siyempre need a lift first hehe
May 25th, 2014 05:24 PM #7169
2012 Tucson - para saan yung black box sa gitna ng dashboard near the windshield?
Thanks
Sent from my Nokia5110i-VgT using Tsikot Forums
- Jan 2003
- 416
May 25th, 2014 06:31 PM #7170how much is a fair price for a 2010 Tucson A/T Gas with 56T km? a friend is selling hers for P690T. is this a good buy? what to check for?
I had a brake booster issue before, it was just the hose. It would take 30 or so minutes to...
Matigas ang Brake Pedal
