Results 1 to 10 of 70
Threaded View
February 11th, 2009 09:36 PM #11
there's a group of wire (probably 3) that is coming from the ecu going to the crdi (diesel injector).
the chip comes with the wiring harness. to done, simply remove the female socket that connects the diesel injector (crdi) and plug the female socket the male socket of the chip. then, connect the female socket that comes directly from ecu to the male socket that goes to your chip.
actually the connection is very easy and it comes with male/female sockets so you will not get lost.
"btw, crdi technology is a whole different with the conventional diesel injector. the latter is controlled by the turn of the engine thru gears whereas crdi is valves woth which opening are controlled by the ecu."
the reason for the above explanation is to inform that this is where the technology of the chip comes in. from the normal fuel delivery that is produced by our ecu this will be now enhanced by the aftermarket chips.
just did a quick search... BYD e6 - Wikipedia Yung 1st Gen BYD e6 pala was released in 2009...
China cars
