Page 18 of 86 FirstFirst ... 81415161718192021222868 ... LastLast
Results 341 to 360 of 1710
    Dec 2010
    #341
    Quote Originally Posted by georgie35 View Post
    Boss, sorry ha, di ko po kasi napansin na may nagpost na lawyer or something, naalala nyo san na page yun? kasi nag-transfer na kasi ng website ang tsikot, bka di ko napansin anong page yun, kung ok lang sana. Ako kasi pinakauna nagreklamo nang ganun na sound sa thread nato. di ko pa kasi nadala unit ko sa casa, masyado kelangan ko sasakyan kasi. at least may laban ako ano man response ng casa. thanks po boss.
    Eto yung link kung saan nagparamdam si Atorni
    http://tsikot.com/forums/hyundai-car...ml#post1742670
    Binigay nya email at website nya.
    First hand experience daw nya na ang Hyundai e nadadaan sa pakiusap
    BTW "panyero" means abogado
    May 2011
    #342
    Quote Originally Posted by vivafoxpro View Post
    I found it na po and sent an email to him. Sana sumagot sya before I go to the dealer. Thank you very much. You've been such a big help. Thanks!
    Mar 2011
    #343
    Try buying from other car manufacturers... puwede di ba.
    In my observation and experience, di talaga pwede. It could quickly go from bad to worse. But in your case, maybe you can share with us your experience...
    Oct 2004
    #344
    Accent 1.4 a/t lang ba affected ng engine knock? Yung m/t hindi ba included since basically the same lang engine nila? So far sa a/t ko pang 2nd fulltank ko na sa petron unleaded and wala pa naman knocking ( knock on wood) hehehe
    #345
    Quote Originally Posted by bratski View Post
    I'm also curious if the 1.6 GLS Blue also has this engine knock issue... sana wala naman.
    Oct 2009
    #346
    Quote Originally Posted by cjv_justice View Post
    I am planning to get blue but having second thoughts now because of this issue experienced by 1.4 owners. And I'm also interested to know if blue has this engine knock issue too. Sana nga wala naman. Otherwise, will consider Honda City E instead.
    #347
    someone posted a comment here that the 1.6 performs very well because of the Blue technology... not sure if he's an owner though.
    Mar 2011
    #348
    Your curiosity has merit since both are bnew models..but obviously it shouldn't be compared with our 1.4L because these two have different engines. It would invariably give a different performance characteristics and response than our 1.4's. Maybe it is better engineered in order to deserve that 'blue' designation and maybe, just maybe a less knock-prone engine. I wouldn't quite spring for the TOTL compact esp when/if price is intruding in the next higher models or kung may comparable or better model sa kabilang brand.
    Apr 2011
    #349
    I agree with
    airolynx
    you should update the system since it is electronic and service center do this for you... do not experiment on gas there is nothing to do with gas. kahit saan kayo magpa gas its ok... kaya lng naman ang dealer gumagamit ng SHELL gas kasi dahil sa ALL shell nag bibigay ng resibo... not unlike sa ibang stations.
    May 2008
    #350
    Is the engine knock an engine problem or a suspension problem?
    #351
    Quote Originally Posted by CooperS View Post
    I'm aware of that... but still...
    Mar 2011
    #352
    mukhang wala na ulit updates ah. totally nawala na kaya yung knock nung mga naka-experience?
    kanina ko lng ulit nagamit yung Accent ko after 3 weeks na idle, so far so good naman. hopefully tuloy-tuloy na.
    #353
    Quote Originally Posted by peerproxy View Post
    Bro.,- it is obviously an engine/timing problem...
    Sales personnel ng HARI,- hindi raw nila alam,- or they're playing dumb...
    13.5K:handinhand:
    May 2011
    #354
    Quote Originally Posted by late_bloomer View Post
    hi,pano nafix yung katok ng makina? this bothers me because I am planning to get a 1.4AT unit this June. Kung marami man yung nakakaexperience nito, hindi kaya makina na ng Hyundai na yung may problem kasi other cars do not or rarely experience this..
    Aug 2004
    #355
    Read the entire thread.
    Three people here have reported knock. And each time it has happened on Petron Unleaded or something cheaper.
    Using Shell Premium, Petron XCS or high octane gas makes it go away completely.
    Using Shell Unleaded makes it less on the first tank, then it disappears afterwards (I assume because the engine is still flushing the old fuel out of the tank).
    Shell Unleaded is the cheapest fuel you can buy at Shell. And the engines work just fine with it. If you have to use Petron, XCS will not cause knock.
    And this problem is experienced, here and there, by all car makes in the Philippines. The problem is called s***ty gas.
    Mar 2011
    #356
    Quote Originally Posted by jsfjr View Post
    yung Accent ko never nagkaroon ng engine knock (as far as how it is described here) so hindi ko din alam kung papano na-fix nung mga naka-experience. most of them just used fuel with higher octane rating, mostly Shell. isa lng din ako sa mga hopeful na sana solved na din ng fuel tong issue na to para maging panatag na tayo.
    Aug 2007
    #357
    sir nung naka xcs ako nagkaroon ng engine knock.. nung nag v-power ako, wala na.. tumawag din yung taga hyundai abad santos, dapat daw high octane fuel ang ikakarga sa accent..
    #358
    I haven't experienced any knock from my 1.4 a/t accent eversince i got it last april 29.
    I only load petron xcs.
    Apr 2011
    #359
    Quote Originally Posted by bhengko View Post
    same here! i just filled my my tank with petron xcs this morning, no knocking issues so far since june7. same thing with shell and caltex. 1.4 M/T by the way
    #360
    It's better to use higher octane fuels sa totoo lang. Pag may long trip kayo try to use the Shell V-Power 97RON or Petron Blaze 100RON.
2011 Accent AT - Engine Knock!
