Page 17 of 86 FirstFirst ... 71314151617181920212767 ... LastLast
Results 321 to 340 of 1710
    Sep 2010
    #321
    Quote Originally Posted by harold13 View Post
    pag pangit ang shifting style may mag knock usually.
    Sir harold, what shifting style do you mean? And what can you suggest regarding shifting in our accent MT? TIA
    #322
    Hindi knock yun, maybe you are referring to LUGGING. Iba yung knock sa fuel yun...
    Mar 2011
    #323
    Maybe what he means is pag nasa maling gear (pangit shifting style) or rpm range for a given speed i.e nasa 15kph tapos naka 5th gear, may maririnig talaga na knock..which to me sounds the same as lugging kasi nahihirapan or strained yung engine.
    Aug 2004
    #324
    Lugging doesn't sound like knock. Lugging is felt as a "kabayo" motion. Knock is heard.
    Mar 2011
    #325
    What noises then accompanies a 'lugging' engine? I think one might hear a 'knock' or two during said lugging.
    Aug 2004
    #326
    You can induce knocking by lugging the engine. Knock sounds like... knock. A tok-tok-tok sound coming from the engine. But you can lug an engine without causing it.
    The sound of bad engine mounts as you lug an engine is more of a loud "TOK" sound when you engage the clutch or let off the gas.
    The sound of engine knock is more like marbles pinging off the engine cover. It's loud enough to hear inside sometimes... "TIK TIK TIK"... This is different from the sound of valves, which is a "tikitikitik" that can be heard even at idle... or of piston slap or rod knock, which is "TOK TOK TOK"... like a metal fan blade hitting the shroud of an electric fan... that last sound tells you your engine is toast.
    May 2011
    #327
    The exact same thing happens to my car. Can I just return it? Napa service ko na but after a week the same problem occurs. When it reaches a certain speed may weird sound as i step on the gas. Badtrip!
    #328
    Dami nang issues ng Accent. :question:
    Kindly start a thread about the issues of the 2011 Accent. Yung andun lahat. Re: knocking, suspension, etc.
    Then ipapakita ko sa HARI.
    May 2011
    #329
    Ako rin same case may katok engine when I reach 30 above speed as I step on the gas. If this is the case can I just get a refund? If not where can we complaint? Pls help me guys cause I'm not familiar with this kind of situation. First car ko kasi to na ako mismo bumili.
    Dec 2010
    #330
    Quote Originally Posted by jerseydriver View Post
    Please read back on this thread. Meron nagpost na abogado who handled a similar case.
    It's nice to come armed when you talk to your dealership.
    May 2011
    #331
    nasan to? pls help me I read na lahat till 1st page di ko makita. Buti na lang you answered. Sana I can get a reply from you soon kasi I'll be going there on Monday.
    #332
    Boss, sorry ha, di ko po kasi napansin na may nagpost na lawyer or something, naalala nyo san na page yun? kasi nag-transfer na kasi ng website ang tsikot, bka di ko napansin anong page yun, kung ok lang sana. Ako kasi pinakauna nagreklamo nang ganun na sound sa thread nato. di ko pa kasi nadala unit ko sa casa, masyado kelangan ko sasakyan kasi. at least may laban ako ano man response ng casa. thanks po boss.
    Mar 2011
    #333
    I should've known NOT to buy first editions of anything..maybe with a few notable exemption. Mas kuntento pa siguro kung 2010 Accent binili ko kaso wala na pala stock nun na bnew. Issues like this won't help Hyundai in the long run. Baka dumating sa point na magka-recall tong model na to which is a hassle for most owners. I already got rid of my older car so balik commuting uli.
    Quote Originally Posted by CooperS View Post
    Try buying from other car manufacturers... puwede di ba.
    Aug 2007
    #335
    yung akin, nawala na yung tunog after the first PMS.. madalas kasi na v-power pinapakarga ko kasi may promo yung shell ngayon hanggan june 15.. 3 pesos lang yung difference ng unleaded sa v-power kaya ok lang.. plus every 1000 baka manalo pa nung sa promo nila.. hehe!
    May 2011
    #336
    does the 2011 Hyundai Elantra have this problem also? i'm planning to check out the Elantra kaya lng baka may issue din na ganito, hwag nalng. saves me time pa...
    May 2011
    #337
    Quote Originally Posted by georgie35 View Post
    if ever someone sends you a reply, painform din ako. ill be going to my dealer sa wed kasi dami nilang dahilan. feeling ko alam nila yung issue pero tinatago nila kasi babagsak sales nila and maraming magbabalik ng unit. if they dont get to fix it within the day, ill bring a lawyer the next day. ill let you know what happens. update mo rin ako kung ma development ka na.
    Quote Originally Posted by waryu69 View Post
    La ata boss. 1.4 Accent lang so far or majority of negative posts.
    #339
    Quote Originally Posted by obet_carlos View Post
    good to hear this sir. hehe manalo sana kau trip to ferrari world
    Jun 2009
    #340
    I don't think there are enough 2011 Elantras running around yet to say so. Give it a few months...
2011 Accent AT - Engine Knock!
