Na biktima kasi ng malalim na lubak last December sa Andaya highway yung left wheel ko.
Tapos dun na nagsimula yung parang may umaalog sa engine bay.
Pinatingnan ko last week , yung engine support at ibang bushing ang tingin nila na papalitan.
By schedule yung Hyundai casa, puro PMS inuuna, kaya sa Bosche service center ko muna dinala.
2015 model ang unit ko.
I went to RoadFit banawe yesterday and bought HiQ brake pads. Malaki din difference ng price from their Lazada store to the physical store price. The front severe duty pads are priced at P1850 in Lazada while it is only P1700 at their store. The rear pads are priced P1140 in lazada while at the store it is P990. Add to that shipping cost.
At mas malaki tipid compared to casa! I'm guessing P3-4k for front pads alone, plus labor.
Replaced the pads today. 1mm na lang kakayod na yung warning tabs. Odo is at 20,270 km. Labor cost = zero!
You are right doc! I checked the battery voltage was only 12.6V. Anyway this made me decide to order a smart battery charger. Lo and behold, the charger indicated that the state of charge was only 20%!!!
I will need to ask the casa if they can adjust the charging voltage when i go for pms maybe next week.
charging voltage of the alternator? it is already controlled with 13.8V to 14.2V range by an IC.. maybe the battery is deteriorating loosing its ability to hold charge. if you have smart battery charger, try to use its RECON mode or REPAIR mode. In CTEK charger, it will charge the battery at around 15V for a time, therefore it is recommended to remove the battery from the car.
or its also possible that the alternator is not giving the 14.2V max to fully charge the battery.
Pangit yung regular HiQ for me. Maingay at andaming dust. Baka mas maganda yung higher end nila, yung Hagen.
Tingin ko Hagen yung nakakabit na OEM sa KDM GS namin. Ceramic and low dust.
Same ingay ng factory installed pads, less dust. Bagong kabit pa lang e wala pa 500km tinakbo. I will know kung mabilis magwear ang rotor maybe after 10000 km pa. Yung old pads nasa 0,5 ~ 1.0 mm kinain sa rotor (more on front, less at rear) so pag pm ko ng 30k km icompare ko.
Re: battery. After charging for 10 hours with the charger the battery voltage is now at 13.8 volts, so up by 1.2volts from yesterday. 1 click start na ulit.
I will try to use the battery repair function this weekend.
Roadfit sa banawe. If you are coming from Amoranto Ave. pag left turn mo sa banawe nasa right side 2nd corner. Or if coming from quezon avenue heading north they are on the left side 2 corners before amoranto.
They have hagen. Also Vic air, aircon, fuel and oil filters.
Naranasan nyo na ba i sagad brakr ng GS nyo lalo coming from high speed?
Kanina sa Pampanga sa hiway I am running 80 kmh then biglang preno ako dahil may naka bike na biglang tatawid nung parating na ako.
Sagad apak ko sa preno may narinig ako parang iyak ng gulong ko. Normal ba yon kahit naka ABS?
Sent from my SM-A507FN using Tapatalk
Di kinaya ng pulse repair yung battery, 2x na ko tinirik. Yesterday morning and today, ayaw na mag start even after 2 times ko na kinabit yung smart battery charger on repair mode. Kanina off ko to open the garage gate, pag start ko nag click na lang. Buti abot yung extension ko. Nag charge naman enough to start pero full charge na agad after only 10 minutes. I think sign na yun na di na talaga kumakarga.
Napabili tuloy ako ng panasonic 3sm D31R na 90AH. P5.5k unplanned na gastos.
