Page 241 of 404 FirstFirst ... 141191231237238239240241242243244245251291341 ... LastLast
Results 4,801 to 4,820 of 8077
    #4801
    CVT ba transmission ng mga CRDi na Gs?
    Sent from my SGH-I717R using Tapatalk
    no. conventional a/t.
    Oct 2013
    #4802
    im just a newbie hir, just bought a gs vgt 2010 preowned last month with odo reading of 33k, meron bang aircon filter ang vgt t san cya located?
    #4803
    Parang nagkaroon ng water leak GS ko nung typhoon Santi. May tumutulong tubig sa mga rear speakers. Never naman nangyari ito before.
    Signature
    #4804
    Quote Originally Posted by GS LOVER View Post
    It is behind the lower glove compartment. You will need to drop the glove compartment, there are 2 tabs on the side. Once the glove compartment is off its tabs you will see the aircon filter compartment.
    Jun 2013
    #4805
    What 3 bike rack can you guys recommend for the gs? yung hindi sa hitch or sa roof...
    Jan 2009
    #4806
    just a small gauge #16 plate will do. effective sya talagang mawawala usok at lalakas ang hatak at di namadududmihan ang intake manifold ng raide natin.. pwede rin sya bypass na lng ang egr yung sa hose para di na mag open.. sa montero dami na nakagawa kahit bago pa lang kahit sa fortuner.
    one way to protect our engine Blank the egr at oil cath can para di mapuntahan ng oil ang turbo came from the engine breather.
    Hhhmmmm,- that is what they are doing too to their MS,- anyone here who has done it? TCI? VGT?
    21.4K:director:
    #4807
    Quote Originally Posted by otil_flores View Post
    Bro.,- thanks for the feedback,- TCi ba ? O VGT? ang variant mo?
    Saan puwedeng ipagawa ito? TIA.
    21.4K:director:
    Oct 2013
    #4808
    Sir, around las piñas area is there a good shop and name of mechanic know how to fix starex engine very well? Thank you!
    Oct 2013
    #4809
    tanx bro for the information
    Oct 2013
    #4810
    newbie lng po! tanong lang po ano ba problema kapag may naririnig na ingit pag tapak sa gas pedal?maingay po sya lalo na kapag bago start pa lang nawawala lng katagalan.san po ba nanggagaling at pano maaayos un?salamat po!
    #4811
    Quote Originally Posted by Automahn View Post
    3SM ang battery ng GS.
    Just had our GS VGT's battery replaced last Friday. The stock battery lasted 3 years and 2 weeks. I got a 3SM Motolite Gold with reverse polarity. It costs P5.6k here in Pangasinan less P500 if you trade in the old battery. It must be cheaper there in Manila.
    I would've wanted the Motolite Excel (top of the line) but only the Gold has reverse polarity.
    Reminds me of my unplanned purchase last January also in Pangasinan. Damn thing didn't last me much more than 2 years though. Wanted to have gotten an AC Delco here in Manila prior to the trip, but when I had it tested, it was still good, supposedly for another 6 months. Ayun, nalamigan ata sa Baguio kaya nagloko na nung bago kami bumaba. Forced to good to get a unit in Urdaneta.
    #4812
    Have you blanked yours already? San ginawa at gano katagal inabot? Thanks!
    #4813
    Quote Originally Posted by gsTCIgs View Post
    Could be your fan belt. Needs tightening or possibly replacement.
    #4814
    Guys,
    Where is our ECU located?
    #4815
    ^^my guess is check mo passenger side kick panel sir. you may have to remove the whole plastic siding. dun ang ecu ng GRX, there's a good chance andun din ang sa GS.
    #4816
    walang manual adjustment ng belt tension. meron yang belt tensioner pulley na spring loaded. so most probable culprit is a worn belt or worn belt tensioner pulley. 3 years ago on my previous GRX the belt cost P2k, tensioner pulley P1.5 k. DIY lang so no labor. since it's basically the same engine the belt and tensioner should be the same, or similarly priced (+ inflation of course).
    it's a pain in the ass to replace. you will need a 14mm socket on a long power handle or a 14mm box with a cheater pipe. di pwede ang ratchet drive kasi hindi mo mare-release after.
    #4817
    * gs lover
    bro, when ko install ito egr blank plate mo? sabay ko na din sa alterra mo
    Oct 2013
    #4818
    ok bro ha excited n ako, galing mo!
    #4819
    Thank you sir!
    #4820
    Quote Originally Posted by zix888 View Post
    * gs lover
    Uy! San gagawin to? Any idea of how long it will take?
2008 Hyundai Starex (Gen. 4)
