Page 678 of 743 FirstFirst ... 578628668674675676677678679680681682688728 ... LastLast
Results 13,541 to 13,560 of 14856
    Jan 2011
    #13541
    Quote Originally Posted by keroroblu View Post
    salamat sir... orig ba tong mga to o meron din copy?
    Sir meron sa sulit don't know if its copy or real
    Jun 2012
    #13542
    Quote Originally Posted by pcuerpo View Post
    enargie, how much ba yung sa casa? i replaced mine with Project Mu, close to OEM ang specs niya, nasa 3k ata siya sa Autoplus... pwede ren yung mga Bendix na pads, those are good too... regarding aftermarket lugnuts, na-try ko na yung Project Kics Leggdura, kasya siya sa stock mags
    Alan, nope, naka aftermarket rims ako nung nag 205/50 ako... really doubt it would be fit the OEM lalo na kung 6" lang lapad nito... kung pwede lang 205/50, tagal ko na nagpalit, kakatakot ng stock tires... nung papunta ako Subic umuulan, nararamdaman ko nag hydroplane... tapos nung pauwi kahit tuyo, di ako kampante
    kidgz, bihira ka makapili ng springrate pero sa BC racing, you can adjust the springrate naman pero i think 8/6 ata yung sakin
    vinz0r, maliit na masyado 205/45, malayo na from OEM spec so may difference sa odo reading... pwede ren 195/50, nakagamit nako niyan... still rubs pero mababa naman talaga yung kotse ko pero kung mag camber lang ako, i dont think it will rub anymore
    i see. akala ko sa stock rims yung 205/50.. pasok naman siya since 5.5" - 7.5" ang 205. anyway, bali 16x7 +45 ang kinabitan mo ng 205/50 tama ba?
    Jul 2012
    #13543
    meron na ba nakasubok ng +40 offset ng rim sa rear. 16x7 or 17x7. May rubbing issue ba both on stock and lowered configurations? Naka 195/50/r16 ako droped about 1.2", mag rub kaya yun kung +40 offset nung rear rims ko? Salamat sa makakasagot!
    Sep 2011
    #13544
    Help naman, napako yung left rear tire ko, been with 3 different talyer / vulcanizing shops same advise lang binigay nila, hindi daw pwede tanggalin yung pako kasi di pwedeng i vulcanize kasi nasa bandang gilid cya. ibabaon lang daw cya which i really find strange kung ganun lang talaga ang paraan.
    thanks
    Jul 2011
    #13545
    Quote Originally Posted by Eejay View Post
    thanks
    ang alam ko basta sa sidewall ng tire ang tama, kailangan ng palitan
    #13546
    Eejay, tama, nandiyan kasi pressure
    enargie, potek, ang mahal naman nun! punta ka na lang Autoplus... for 5.2k, you might be able to afford the performance pads already ng Project Mu... forgot the model pero alam ko nasa 4k to 5k na ren ata yun, hanapin mo na lang si Kitt, he'll be glad to help you out for the lugnuts, ang bilis naman na-loose thread niyan... ako, gamit ko pa ren yung stock ko ever since... changed to stock rims twice already (this is actually my 3rd set already) and walang problem
    Alan, 16x6.5 yung rims ko dati nung naka 205/50 ako if ever, baka 195/50 pa ren ako siguro... basta kailangan ko ng magandang tires
    Jun 2012
    #13547
    Quote Originally Posted by krm View Post
    boss mike, nung naka 17s pa ako (17x7.5 +45) with 205/45 tires then added 1/4" na spacer sa likod and naka drop around 2 fingers remaining, hindi naman ako sumasabit. Pero nung nag load na sa likod, meron na. Though afaik ang 1/4" kasi is around 6mm so i was sitting around 39 offset nun.
    thanks
    boss eejay, ganyan din nangyari sa innova namin. Well hindi napako pero nagka singaw din sa may sidewall. I forgot kung ano yung term doon. Napagawa ko sa BSA (brigestone alabang) pa yung akin. You can go to them to check :D
    anong rims yan pao nung 16x6.5 ka? what offset? para lang may idea parin ako pag nagpalit ako ng tires. :D
    Jun 2010
    #13548
    Quote Originally Posted by s10pao View Post
    Tingin ko nung last pms ko di maganda pagkalagay ng lugnut then ginamitan ng drill gun kaya napwersa. One of these days punta ko kay Autoplus to check ung brakepads.
    Thanks
    Jul 2012
    #13549
    Quote Originally Posted by sabawballs View Post
    I see, Siguro 3mm spacer nalang para sur, kelangan ko lang para mailagay yung center caps lol Tumatama kasi sa bearing cover sa rear. so if ever +42 ako sa rear on 195/50 sabit pa rin kaya?
    #13550
    Eejay, palitan mo nalang sir yung tire na yan ng spare tire. Tapos yan nalang ilagay mo as spare.
    Ang alam ko kasi, basta sa gilid.. di na talaga pwede.
    Jun 2012
    #13551
    yan din pala yung nangyari sayo.. same tayo na hindi malagay yung centercap sa rear kaya naglagay ng spacers. Not sure kung okay na ang 3mm. Pero kasi sa 1/4" parang saktong sakto lang yung kabitan nung center cap. Try mo rin muna pero i think sa +42 offset with 195 tires e safe ka na
    Sep 2011
    #13552
    Thanks mga bossing, try ko muna daan sa Bridgestone Alabang since isang tumbling lang yun from the office to have it checked. pag di na kaya, yung spare tire n lng yung gagamitin ko.
    #13553
    Alan, Gramlights 57 Optimise yung rims na yun, 16x6.5 tapos +45 ang offset sobrang nagsisisi ako at pinakawalan ko yun... sale ko pa nakuha sa Autoplus, parang nasa 40 or 45k na lang ba?
    eto siya, di pa common kulay at bagay sa GE
    Jun 2012
    #13554
    huhuhuhuhuh!!!!! sayang hindi ko makita pic dito sa office.. pero nakita ko yung optimise parang XD9 :cry:
    #13555
    Ang tikas!
    Jul 2012
    #13556
    kumuha ako 3mm spacer pasok naman na centercap, wala rin rubbing issues. Happy na ulit. bali +42 ako sa rear, kaya ka siguro nag rub noon dahil 7.5 yung lapad ng rim mo, yung sakin 7" lang so may konti pang allowance.
    Jun 2012
    #13557
    yup possible and kasi 17s with 205/45 tapos almost 1.5 finger gap
    #13558
    Alan, yup or mas hawig siya actually sa 11R since puro spokes... gwapo siguro lalo kung naka coils nako at walang fender gap
    Jun 2012
    #13559
    pati ako nalungkot boss pao :cry: buyback mo nalang.. :D
    #13560
    tagal ko na nabenta to haha parang 2010 pa ata tapos tiga Pampanga yung bumili pero naka EK... di ren nagtagal sakin to, less than a year... swerte nung nakabili at supah fresh pa...
Second Gen. Honda Jazz/Fit
