Page 499 of 743 FirstFirst ... 399449489495496497498499500501502503509549599 ... LastLast
Results 9,961 to 9,980 of 14856
    #9961
    Quote Originally Posted by dambee View Post
    Hindi ko na inudjust, masaya na ako sa adjustment na ginawa mo
    ayus boss! sama kana sa mga GT nyan boss
    Apr 2012
    #9962
    ung 34.2K boss? 2nd hand ba to?
    Thanks! 34.2k kuha ko sir.
    Apr 2012
    #9963
    BC stands for Buddy Club? tama ba boss?
    #9964
    Quote Originally Posted by maloyski25 View Post
    brand new daw nya nabili boss sa autoline.
    BC is different from Buddy Club, taiwan made din yata tong BC. marami sya good reviews sa fitfreak.
    #9965
    Quote Originally Posted by imogen View Post
    OO sama talaga ako dami ko matututunan haha!
    #9966
    34.2k brand new sir! sa autoline ko kinuha..
    eto site ng BC BC Racing - North America
    Jul 2012
    #9967
    *dambee: sir ano ground clearance nyo sa coils nyo sir? Especially sa front chin.
    Jan 2012
    #9968
    Quote Originally Posted by krm View Post
    Good day sirs,
    New to the forum here. Just got my 2012 GE recently and was pondering on getting replacement wheels. Been back-reading and learned alot, Just want to clarify,
    -if my rim is +48 offset on a 16x7 on a 195x45 tire, will this fit the car without any problems like rubbing on the fenders or the wheel well (when carrying heavy loads)
    -Haven't seen any Rota rims with a +48 offset mostly +45 any ideas where I can get one or alternatives?
    -If I were to go 17x7 using 205/45 will it still clear the fender and wheel well?
    note that my car is riding on stock height, and I have no plans of lowering my ride.
    Thanks in advance!
    Hi krm, welcome to the GE world. were glad to help you on this one.
    if you are going for rota, a +45 offset is the easiest that you can get. as anything higher than that are already 5 X 100/114 bolt pattern. our GE uses 4x100 lug pattern, and if possible don't go over more than 7 inches in width. here are some of my reco for you since same as you am on stock suspension and have no plans of dropping.
    16s
    16x7, 4 x 100 bolt pattern, +45 pataas offset , tires: 195/50/16 or 205x50/16 - Am personally on the 205s but gets rubbing very seldom but ONLY on the left driver side fender during quick dips, if i went for the 195/50/16 i dont think i would be having this slight now. charge to experience na lang.
    17x7, 4 x 100 bolt pattern, +45 offset pataas, Tires: 205/45/17 , 195/50/17 --->>> this will surely clear the fender liner against rubbing basis doing the math.
    #9969
    idol talaga yan si boss Jay, napakabait at matulungin
    dambee, nice GE, pakita mo naman yan sa mga GT ilang inches or fingers gap mo sa harap? and tire specs?
    gusto ko na mag-coils! baka yun na ang sagot sa aking rubbing hehehe
    #9970
    Quote Originally Posted by pcuerpo View Post
    hahaha! boss baka maging anghel ako nyan! :evillaugh
    coils talaga sagot dyan sir! wag kana palit ng tires, sayang yan,, pero kung ma swap mo sa bridgestone na walang dagdag, edi go na! hehehe! pero really can't say na mawawala rubbing by switching to 205/45 since this tire will be thicker than 215/40,, 205/40 ang alam kong walang sabit, pero you will lose approximately 3kms/100kms on your odometer + comfort..
    Jan 2012
    #9971
    try this site boss, Tire Size Calculator, yan ginagamit ko palagi for reference
    205/45/16 pala yung malayo!
    deym, malapit lang pala yung 205/45/17 from stock! pero baka labas na yung rims ko sa 205, kasi ngayon pa lang sa 215, parang labas na, yari to pag na-gutter...
    pag-asa ko na lang make my suspension stiffer
    naka 205 ako pau, hindi naman labas yung rims + may rim guard yung ss595, am not sure kung meron ang ev0 595.
    Jun 2012
    #9972
    paps bayen how are the feds ss595? thinking if i'll get the feds or nankangs ns2.. Consulted with others as well.
    #9973
    Check ko later sir bigay ko sayo exact kung ilang millimeters nalang ground clearance ko from front chin.
    Thanks pcuerpo! Oo nga idol ko na din yan c sir Jay! Tire specs ko is 215/40/17 Toyo Proxes t1r. barely kasya ang 2 fingers both front and rear. mga 1.5 fingers.. so far wala naman rubbing sa front/rear ko kahit 5 passengers.
    Jul 2012
    #9974
    *bayen: thanks for the input sir. Naisip ko nga rin na mag rub yung 205's. Had a similar problem with my FD before, kaya very carefully na ako ngayon so I guess 17x7 +45 with 195/50 is the safest bet to clear both the rear and front fenders and liners. Please correct me if I'm wrong.
    Sa mga naka ganyang setup, significant ba change sa ride comfort and fuel economy?
    Jan 2012
    #9975
    Quote Originally Posted by sabawballs View Post
    so far good naman sya sir. been using mine for almost 2 years now and until now parang bago pa din. may buhok pa nga e. recently nag-rotate nako, around 8,000 KM, comparing the front tires to the rear one, dun mu lang talaga mapansin yung sign ng pagka-upod, no signs of cracks, on sidewall on all 4 tires. on dry - superb performance and grip, on wet - have not put it to MAX test like intentionally making it slide, pero with my driving style, hindi pa naman ako nawalan ng control sa wet road. my trips usually include daily city driving, plus occasional trips to carmona or tarlac via NLEX, SCTEX or SLEX.
    sir jonas used ss595 on his GE before, after 3 years(i think), nag-ka cracks daw yung sidewall yung kanya. natakot nga ako dito e, hope mine wont share the same faith. so far naman yung kanya pa lang yung narinig kong case na ganyan. i have another friend using ss595, he is on 17s, so far okay pa naman din yung kanya.
    NS2 is not bad too, built for tropical weather to. my brother in law has this one on his City okay naman daw. my only gripe against the NS2 is walang rim guard. instant gutter ka dito kapag hindi ka maingat, yung SS595 meron so safer on gutters. hehehe
    another option to look into is nitto neogen, almost same price as those 2 mentioned above. may rim guard din. so far wala pakong negative feedback na narinig from this one.
    Jan 2012
    #9976
    am positive on this setup na walang rubbing (17x7 +45 , 195/50). pasok na pasok pa to lalo na sa likod.
    ang maselan lang naman kasi talaga sa GE naten is yung sa harap e. its a bitch trying to look for +53 offset. meron naman pero too expensive.
    may naisip pa nga ako e, since spoon theme ko what i would want to do is like this,
    i'll get 2 pcs orig CR93 rims (17x7 +53 offset) slap 205/45/17 tires on it for the fronts
    then 1'll get 2 pcs ROTA FRK (17x7 +45 offset) slap 205/45/17 tires for the Rear.
    in this way, i dont get rubbing sa harap, rear wheels wont look TOO tucked in, pero wala pa din rubbing. + less expensive. hehehe
    Jun 2012
    #9977
    Quote Originally Posted by bayen View Post
    this.. mukhang feds nga kukunin ko kung ganun. Interesting yung nitto ah but per pcuerpo i think 6k din? medyo malayo narin. How about the road noise/ugong of the ss595? kapatid ko lang kasi may experience pero sabi niya medyo maingay nga.. pero what doe this ingay mean? kasi ang stock tires naman rinig mo ang road noise. eheh!
    Jun 2012
    #9978
    meron palang 195/50 na 17s? :D pero hindi ba masyadong beefy na knowing that 205/45 nga medyo beefy narin? hehe!
    Oct 2005
    #9979
    Yan ang perfect sa Jazz (though bit rare). Since 185/55R16 ang biggest stock.
    #9980
    imogen, idol, di na nagreply sakin yung kausap ko sa DKC... di siguro pumayag ang boss niya... pareho kasi by order so lugi din siguro sila kung sakali... mas madali kung available yung RE002 sa kanila... pero try ko nga muna ayusin to bago ko talaga papalit unless straight swap i-offer sakin ng DKC
    sabawballs, if on a budget, NS2 ka na
    dambee, ang taas pa pala ng harap mo... yung sakin kasi less than 1-finger gap... weird kasi kung baket pareho tayo ng specs pero sakin nagrurub... feeling ko kailangan lang maging stiffer and umangat ng konti... sana yun na ang sagot! :praying:
    Bry, boss, meron bang 195/50/17? parang ang hirap maghanap nung specs na yun! i'd suggest 205/45 pag 17s
Second Gen. Honda Jazz/Fit
