Results 151 to 160 of 180
- 54,230
February 14th, 2018 11:48 PM #151
- Jan 2018
- 844
February 14th, 2018 11:53 PM #152
- 54,230
- Dec 2018
- 10
December 4th, 2018 10:24 AM #154
- Dec 2018
- 10
December 4th, 2018 10:27 AM #155Hindi naman aabot ng ganyan kalaki aabutin. Dahil usually solenoid ang pumapalya at dapat may proper maintenance din. May nabibili din naman mga parts nyan second hand nga lang kung nagtitipit ka at may gumagawa din po...sa banawe meron yan kaso ung iba gagawin swap na at ikaw na ang magdagdag.
Sent from my SM-J710F using Tapatalk
- Dec 2018
- 10
December 4th, 2018 10:30 AM #156Pwede mo pong kunin sir kung gusto nyo po. Pero syempre dahil second hand na at di nyo po alam history. Kailangan nyo po ipa-pms yan. Para macheck po lahat. Ang mga karagdagang tanung nyo po pwede nyo pong itanung doon sa pagpapacheck up nyo ng car. Or pwede po kayo maghire or magpasama sa bihasang mekaniko at electrician para sigurado.
- Dec 2018
- 10
December 4th, 2018 10:32 AM #157
- Dec 2018
- 10
December 4th, 2018 10:38 AM #158Maaaring magkaproblem po yan dahil maselan ang langis nyan. At dapat cvt fluid ng honda talaga ilagay dyan...base sa experience ko. Car ng tita ko nagpapalit ng fluid sa talyer pero ang inilagay is ATF which is di compatible sa CVT ng honda. Nanginginig ng malakas ung car (honda city idsi). I tried to flush ung atf and change it to cvt fluid from honda around more or less 3k pesos ang gallon. At nagbago, naging normal ang andar, change gear ng car. Sana makatulong po ito sa inyo. Never po kayo maghalo ng ibang langis dahil may specific grade ng langis ang bawat makina or trnsmission ng car.
- Dec 2018
- 10
December 4th, 2018 10:40 AM #159
- Dec 2018
- 10
December 4th, 2018 10:48 AM #160Try nyo po ireset pcm nyo or try removing negative terminal ng battery nyo for 10 to 1t minutes then observe nyo po. If the problem still exist. Check nyo po ung inhibitor socket nyo at transmission socket sensors under the hood, try to remove and clean it with electrical cleaner. Of course u have to disconnect battery terminal before doing this. Kapag binuksan nyo po ulit ang car at nagbliblink pa din po. Try nyo po i-wiggle ung mga socket connectors from transmission while the ignition is on baka loose or damage wire or even corroded socket ang problem.
Not sure if functional nga ba pero yung ibang turbo daw water-cooled na versus oil-cooled. Kaya...
0dometer problem
