Page 17 of 18 FirstFirst ... 7131415161718 LastLast
Results 161 to 170 of 180
    Feb 2007
    #161
    I have 2014 honda city VX CVT, my car transmission has P R N D S and does not have L. Is this procedure applicable to my car or should I skip the L? Thanks for any one whi will reply. I have a problem with my car unusual shifting pattern since i remove the battery. It behave unusual speciallybwhen down hill it revs at high rpm as it was engine breaking suspecting downshifting the transmission. Need help from u guys . Really appreciate for your support. Thanks
    1. Start the car and run it to operating temp (no other electricals must be used like aircon, radio, power windows, mirrors, lights). Keep the doors closed so that the dome light is not on.
    2. Shut down the engine
    3. Start engine again and turn on headlights, without operating any other electrical load (other than headlights).
    4. From P(ark), shift to N, D, S, L, S, D, N while waiting at least 2 seconds before shifting to the next position
    5. Repeat the N, D, S, L, S, D, N sequence for 3 times
    6. Turn-off headlights
    7. Shutdown engine
    8. Drive and investigate if the fuel consumption decreases.[/QUOTE]
    #162
    Quote Originally Posted by Firefox2007 View Post
    7. Shutdown engine
    [/QUOTE]Reset procedure did nothing? Odo clocked? CVT fluid changed?
    #163
    7. Shutdown engine
    [/QUOTE]
    Bro, as far as I know, this procedure was for the old CVT of Honda, circa 2005ish...
    #164
    6yrs na. That cvt fluid needs some changing...
    Feb 2007
    #165
    Follow up on this cvt reprograming. Is this applicable to honda city VX model 2014 model? Lately i experienced my city cvt transmission unusual shifting since the battery was disconnected. The rpm goes up when decending down heel then when highway cruising sometimes rpm is hunting UP & down causing the engine to rev high. I brought it to honda casa they diagnosed and found no fault , and they are recommending palit ng transmission!!! Need help if any one of you have to recommend on me. Thanks
    It is encouraged that you have your battery changed at Honda Cars because they need to reprogram your CVT (for those who has this type of transmission in their City or Jazz cars). Trouble is, there, the battery is expensive and you pay for the reprogramming activity.
    So with this, you can buy your battery from any of the dealers and reprogram the CVT yourself. A much more cost-effective alternative.
    I am just wondering why these car manufacturers did not use non-volatile memories, like flash to store the program values so that you need not program the CVT when you change battery. Well.....
    5707:tumbleweed:
    [/COLOR][/QUOTE]
    Feb 2007
    #166
    Bro, as far as I know, this procedure was for the old CVT of Honda, circa 2005ish...[/QUOTE]
    Thanks bro... nagkakaproblema kasi yung cvt ng city ko 2014 VX model. When road decending nag Hi Hi rpm which is very unusual then pag crusing highway sometimes rpm will drop and up again. Any recommendation on this? Dinala ko sa casa and they recommend palit ng trnasmission!!! Wala sila makita nung nag scan sila
    #167
    Thanks bro... nagkakaproblema kasi yung cvt ng city ko 2014 VX model. When road decending nag Hi Hi rpm which is very unusual then pag crusing highway sometimes rpm will drop and up again. Any recommendation on this? Dinala ko sa casa and they recommend palit ng trnasmission!!! Wala sila makita nung nag scan sila[/QUOTE]
    Ganun na lang palit transmission? Aba hanep din.
    We have the same unit, so far wala pa ako na experience na ganun. Wala din reported na ganun issue dun sa car club.
    I changed my battery 3x na siguro, hindi ko ramdam yung relearning nung system.
    #168
    Can you share a bit more info, Firefox sir? Kms clocked, maintenance, fluid change & usage history?
    CVTs are non-rebuildable. If it has indeed conked, you're likely looking at a new tranny.
    Try some other dealership for 2nd opinion. Let's hope for the best.Honda Jazz/City CVT Reset Procedures
    #169
    Sent from my iPhone using Tapatalk[/QUOTE]
    have you brought this to a transmission specialist? baka andun lang ang salvation without have to replace the whole cvt?
    #170
    Bakit sabog yung quotation ng posts
