Page 16 of 18 FirstFirst ... 612131415161718 LastLast
Results 151 to 160 of 180
    #151
    Quote Originally Posted by turbokiller View Post
    Mga sir tanong lang kung bolt on ba springs ng 2010 jazz sa 2018? Tia
    i am not sure, what you mean by "bolt on".
    but yes, almost everything in the car is "bolted on", if that is what you are asking. they are not welded on.
    the glass isn't. the windshield glasses are glued on.
    Jan 2018
    #152
    I think he was asking if they were compatible for his intended application [emoji51]
    #153
    Quote Originally Posted by SpinCycle View Post
    ah, ok.
    noted, po.
    Dec 2018
    #154
    Quote Originally Posted by pongzkiedos View Post
    Bka my nag bebenta jan honda jazz
    Honda city civic 1.3 manual 200 to 230k pogi pa at sasakayan nalang hahaha
    Dito po sa fairview meron po pero no idea pa po sa price...dahil sinabi lang sa akin na may nagbebenta ng kaibigan ko.
    Sent from my SM-J710F using Tapatalk
    Dec 2018
    #155
    ang tanong ko po sana kung totoo po bang 100k to 300k ang pagawa ng CVT box if sakaling pumalya ang CVT transmission ni Honda city
    at kong may nabibili or na gagawa pa ang CVT box repair or need ba talga palitan ng buo..?
    Hindi naman aabot ng ganyan kalaki aabutin. Dahil usually solenoid ang pumapalya at dapat may proper maintenance din. May nabibili din naman mga parts nyan second hand nga lang kung nagtitipit ka at may gumagawa din po...sa banawe meron yan kaso ung iba gagawin swap na at ikaw na ang magdagdag.
    Dec 2018
    #156
    Tanong lang po sana masagot nyo tong tanong ko..
    May binebenta sakin angfriend ko na HONDA CITY IDSI MATIC 2008
    makinis , swabeh , at maayos ang car
    kaso baka sakin abutang ng CVT problem... kya nag aadvance na ako .. nababasa ko kc CVT is around 100k to 300k kaya na tatakot ako.. sana may maka sagot nitong tanong ko salamat
    Pwede mo pong kunin sir kung gusto nyo po. Pero syempre dahil second hand na at di nyo po alam history. Kailangan nyo po ipa-pms yan. Para macheck po lahat. Ang mga karagdagang tanung nyo po pwede nyo pong itanung doon sa pagpapacheck up nyo ng car. Or pwede po kayo maghire or magpasama sa bihasang mekaniko at electrician para sigurado.
    Dec 2018
    #157
    Quote Originally Posted by ckyrie View Post
    Sir need help kaka buy ko lang ng honda city
    Ano pong klase ng help need nyo?
    Dec 2018
    #158
    Quote Originally Posted by Boomy View Post
    Good pm mga sir! newbie lang po... First car ko is Honda city 04 AT. Upon checking mababa level ng Trnsmission fluid ko, Nag dagdag po ako ng Shell MD3 na atf. nagresearch ako na dapat pala is honda CVTF. magkakaprolema po ba yun? Kailangan ko na ba papalitan at idrain?
    Maaaring magkaproblem po yan dahil maselan ang langis nyan. At dapat cvt fluid ng honda talaga ilagay dyan...base sa experience ko. Car ng tita ko nagpapalit ng fluid sa talyer pero ang inilagay is ATF which is di compatible sa CVT ng honda. Nanginginig ng malakas ung car (honda city idsi). I tried to flush ung atf and change it to cvt fluid from honda around more or less 3k pesos ang gallon. At nagbago, naging normal ang andar, change gear ng car. Sana makatulong po ito sa inyo. Never po kayo maghalo ng ibang langis dahil may specific grade ng langis ang bawat makina or trnsmission ng car.
    Dec 2018
    #159
    Quote Originally Posted by mykel04 View Post
    Sir last question po sir ung po bang gearbox oil un po ba ung cvt na oil? Honda jazz vtec 2006 model A.T po pla sskyn q.
    Ang gearbox oil is for differential at ang cvt oil naman po is for transmission po.
    Dec 2018
    #160
    Quote Originally Posted by Carmina Tuyung View Post
    Guys ask ko lang, I have here Honda Jazz 2004 model. Problem is 'bout "Blingking drive "D" indicator, Dropping RPM (Revolution/minute) and Lw power". Kapag inaapakan ko kasi yung sa gas imbes na magtuloy tuloy yung pagharurot, humihina yung pag abante. Bakit ba nagkakaganun?
    Try nyo po ireset pcm nyo or try removing negative terminal ng battery nyo for 10 to 1t minutes then observe nyo po. If the problem still exist. Check nyo po ung inhibitor socket nyo at transmission socket sensors under the hood, try to remove and clean it with electrical cleaner. Of course u have to disconnect battery terminal before doing this. Kapag binuksan nyo po ulit ang car at nagbliblink pa din po. Try nyo po i-wiggle ung mga socket connectors from transmission while the ignition is on baka loose or damage wire or even corroded socket ang problem.
Honda Jazz/City CVT Reset Procedures
