Page 32 of 62 FirstFirst ... 2228293031323334353642 ... LastLast
Results 621 to 640 of 1223
    #621
    Rayleigh, what tint did you intall for your unit? Ill also be getting a white 2.0S.
    #622
    meron ba dito thread ng CRV 2014 na nagpalit ng stock radio to TV/stereo?
    #623
    Just got the new toy! :-)
    May 2011
    #624
    ^CVT naba bro? Post ka FC.
    Feb 2011
    #625
    Congrats Sir Rico! Join ka na din s HCP forum under the 4th-Gen thread. Next weekend may track day sa Tarlac. If anyone is interested, sali na!
    #626
    Quote Originally Posted by sientobente View Post
    Is that a facebook forum?
    Feb 2011
    #627
    Quote Originally Posted by riccomina View Post
    It's Honda Club of the Philippines, in facebook, it's "Honda CRV Phillipines". I'm gonna use my V on the track this weekend, not really gunning for a good lap time but more on stretching the legs of the car.
    #628
    Will do! Thanks!
    Feb 2011
    #629
    Quote Originally Posted by DYC View Post
    Sa CRV OC na forum sir marami na nagpalit. They use an adapter that you can get from Amazon or Ebay. It's called an RP4-HD11 to let you still use the MID and your steering wheel controls.
    Jul 2012
    #630
    Napansin ko kanina CR-V ko may momentary flicker ng electrical power everytime magkakaroon ng load tulad ng aircon compressor or pag ino-on ang head light or fog light.
    Pansin ko yung flicker sa back light ng instrument cluster and yung abs indicator iilaw din momentarily lang mga one second lang then normal na uli. Pati yung radio mag-o-off then on din.
    Nag start ito kanina after ko magpa-car wash. Gen 2.5 yung crv ko. May naka same experience na rin ba sa inyo mga sir?
    #631
    Quote Originally Posted by Mikoy10 View Post
    On my opinion, I would suspect two possible factors regarding to your concern about the momentary flicker of electrical power on your car when another load activates. The followings are:
    1.) Battery.
    ➡Not getting enough charged to stabilized current and voltage to your cars electrical needs.
    ➡Or it might be due for a new replacement.
    ➡Or underrated battery capacity to your car electrical needs.
    2.) Alternator.
    ➡It might not be giving enough or sufficient current to charged your battery. Have it checked by your car electrician.
    Sent from my Starmobile UP+ using Tapatalk
    #632
    Quote Originally Posted by rodetor View Post
    1.) Battery.
    2.) Alternator.
    might i suggest another possibility...
    loose or poor electrical connections. start with the battery connectors, then the alternator cables.
    #633
    I agree with dr._d.
    Jul 2012
    #634
    Thanks sa reply Rodetor & dr. d. Yung battery ko bagong palit lang last month, chineck ko yung terminal connection kanina secure naman. Pero posible nga di maganda charging or poor connection sa alternator. Check ko mamya. Thanks.
    #635
    Saan po ba na-aadjust ang cut-off line ng headlight for crv2014?
    Para po kasing medyo mataas yung bigay ng ilaw. Kakahiya sa kasalubong pag gabi.
    Mar 2015
    #636
    Kindly check din mga fuse. I had an issue din last month nagfliflicker then me time medyo matagal un interval ng blinking. Checked wires and connection then finally na trace maluwag un fuse.
    Mar 2015
    #637
    Mar 2015
    #638
    Hello! Ask ko lang. May garalgal kasi na naririnig kapag umaarangkada crv ko. It happens kapag paangat kalsada. May humps sa mid way ng paangat na kalye dito sa amin, once i stop sa hump and then i start to accelerate to gain momentum saka cia parang gagaralgal (parang Grrrrruuuuugggggg un sound). Even at full stop tapos pwersahin ko un gas to have sudden acceleration gumagaralgal cia. Sound comes from the drivers side. It happens only when im stepping on the gas. After the garalgal driving seems normal naman na. Any ideas?thanks!
    Jul 2012
    #639
    Quote Originally Posted by rrravennn View Post
    Thanks sir. Ok na crv nawala na yung flickering. Chineck din ng mechanic mga fuse ok naman. Binugahan nya
    ng compressed air mga elec connectors sa engine compartment. Ngayon di na bumalik problema. Posible nga nag cause nung nagpa carwash ako.
    Nov 2013
    #640
    Good day pips, I have a gen 2, and planning to have the oil changed and replace ung rubber head gasket (kase my leak according s casa) any recommended shops around makati n maayus gumawa? Salamat :D
Honda CRV [continued]
