Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    slight kickbacks suck with its matching knocking sound ugh!!!! faqqqq
    anyways as some have mention.. it does stick out of center. was driving along nlex-sctex and it was veering slightly to the right.
    sana hindi busy sa Honda GH. Any recommended SA there for warranty checks?
    Nov 2011
    I bought my extended warranty sa GH, they are very well aware of the EPS issues.
    I've shared here it before, I'll share again, while talking to the warranty processor (who also sold the extended warranty to me), I overheard him talking to a tech, "ahh Civic yan diba, oo EPS yan".
    I have his calling card, will share it here pag nakuha ko sa glove box.
    What I'm more interested is if new na yung part# nung ni rereplace. If not, then babalik din yan eventually diba? I hope you can update this thread pag napa replace mo including the part#.
    Quote Originally Posted by TheUninvited View Post
    bro asahan ko yan calling card. 7am pala sila nag bubukas. wala ako booking but ill be first in line hopefully. crossing fingers
    suspension adjistment.. daming pula..
    Hunter Pro Align gamit..
    Oct 2018
    The steering DOES stick out of center!!! Akala ko ako lang!
    Ang straight sakin is the steering wheel shouldbe turned a wee bit to the left. If straight na straight, veers to the right nga din.
    Slight issue naman sakin, pero will have this checked sa CASA sa sixth month. Or would you guys suggest to have it checked ASAP?
    Quote Originally Posted by ironman06 View Post
    It's likely just off toe. Nothing a good alignment can't correct, sir. Delaying may show on tire wear.
    dropby your dealer. wala gaano tao hahaha.
    if i were you, id take it to your dealer. checking isnt expensive 10$ or so
    Oct 2018
    Thanks, Sirs! Will drop by this weekend. Ill provide an update
    Nov 2011
    *StockEngine
    Sorry forgot about the calling card.
    Anyway, napa check mo na EPS mo?
    *Ironman,
    Pina align ko din sakin kase fresh from casa off-centered din sakin eh.
    Dapat less than 1k KM odo for the alignment warranty. Although green na sa report, di pa din centered, so pinatira ko sa Servitek.
    Manual adjustment na lang para gitnang gitna.
    *StockEngine
    *Ironman,
    so far ok naman after adjustment. alao they checked kuno the eps and wala daw errors. iniiisp ko kung saan pwede ilong drive eh.
    Nov 2011
    Ahhh.. So walang sound yung sayo pag sagad? Kase once they hear it, no need for errors.
    And the EPS light won't turn on for this particular issue of the Civic FC.
    ah di ko pa natest full turn. ill test in a few...
    Oct 2018
    *StockEngine
    *Ironman,
    Seriously?? Sana pasok pa din, nakaka 2k palang ako eh. Pero hassle if di na covered. Oks lang naman if i pay pero sana minimal
    Magkano inabot sa Servitek? Hindi ba ma-void ang warranty sa Casa dahil sa labas pinagawa?
    Dapat sinabi sayo ng SA pagka deliver yan.
    Oct 2018
    Wala siya nabanggit about dun sa alignment warranty. Will have it checked nalang
    Nov 2011
    600 sa Servitek. Warranty will not be voided, alignment lang naman.
    Feb 2017
    For EPS replacement, the best daw sa Honda Pasig. Dun nire-refer ng kagroup namin yung may eps issues na member namin.
    For simple mechanical rattling from normal wear and tear, there is actually a very simple fix. You just need to tighten the rack guide by 1/8 turn (40 degrees to be specific) and your steering is good as new. Don't listen to the P80K replacement offered by the casa or the P5k "overhaul with engineering plastic bushing" BS offered by roadside hacks.
    There is a rack guide adjustment service and a special tool (PN: 07AAA-TL2A100) from Honda that makes this in-situ service possible and quick - less than an hour if the mechanic knows what he's doing. There is no need to bring down the subframe or align wheels after. Only the bottom cover needs to be partially bent down to perform the procedure.
    This "rack guide" (by Honda's lingo), "yoke", "preload", "slipper", "half-moon" (in local lingo) adjustment is present in all rack and pinion steering systems - hydraulic or EPS. So this applies to non-honda vehicles as well.
    If your unit is relatively new, by all means claim the entire EPS assembly under warranty. If not, this simple rack guide adjustment should buy you some time before a replacement. You can probably get away with one or two adjustments before the clearances become too big to be mitigated by the adjustment. Greasing the rack guide port and the rack itself also helps. Use tacky (NLGI grade 1 or 2) lithium or calcium-based grease as normal mineral grease would degrade the rubber o-rings and plastic bushings/gears in the EPS unit.
    Jan 2016
    Is this true for all early models? The ES is well known for this issue.
    Apr 2005
    Quote Originally Posted by Woof View Post
    So this is the P5K EPS fix being offered to me in Banawe last Saturday. May naririnig kasi kaming alog sa may front tire.
Civic X (10th Gen) Steering Issues
