Page 29 of 62 FirstFirst ... 1925262728293031323339 ... LastLast
Results 561 to 580 of 1223
    Feb 2011
    #561
    Quote Originally Posted by glntVR View Post
    Most likely its Gen 2.5, the MMC of the 2nd gen had updated gauges
    yup it's the Gen 2.5, it has a similar MID with the Gen 3 and Gen 4 where it has a moving bar for the fuel consumption.
    Sep 2009
    #562
    Hello peeps. The original alternator broke down at 70k kms. Buti na lang may inabutan akong surplus sa Banawe which costed 11k. Bakit ang aga yatang bumigay ng original alternator? I am using a 2008 3rd gen CRV. Naka-sound setup with 1 subwoofer, 2 amps, 4 kicker separates with 4 kicker tweeters. My low headlights are modified to HIDs. Any tips on how to lengthen the alternator life? Thanks!
    Feb 2011
    #563
    Quote Originally Posted by retsuyaken View Post
    Adding an additional battery? Although an alternator breaking down is might be more of a mechanical failure than an electrical one. Coz a CUV's alternator is usually more than 100 amperes which should be enough load. If hindi kaya ng kuryente yung setup, usually babagsak lang naman yung boltahe, and instead of the alternator getting broken, it's your audio setup that will usually take the that toll.
    Sep 2009
    #564
    Thanks sir.
    Mukhang unti-unti nang nalabas ang depekto ng crv ko. Nagjejerk siya kapag steady ako sa 10 km/h. Yun bang biglang baba tapos biglang tataas ang rpm. Pero kapag mataas na sa 10 km/h ang aking takbo, hindi na nagjejerk. Ano kaya ang possible cause noon mga sir?
    Nov 2014
    #565
    hi..I maybe out of the thread but just to ask if anybody knows when honda mobillo will be available here..1.5 idtec..coz ive seen in youtube that it has a lot of good things in it especially in FC 24.2l/km, good engine power 100ps and torque of 200Nm..tnx
    Feb 2011
    #566
    Thanks sir.
    I experienced something like that on my previous EK(civic), ang pinalitan were the high tension wires, because it wasn't giving the spark it needed. I recommend to have it checked.
    A good shop that specializes in Honda is Jeff De Leon's Forcedspeed. He has a shop near katipunan.
    Jeff De Leon - 09176280700
    #567
    Quote Originally Posted by sientobente View Post
    it's a 2.0 AT Modulo sir. the audio setup i have is a focal/audison combination. running subless as of now(wala pang pera ) but here are the gears installed:
    Focal PS 165 FX
    Audison SR4 4 Channel Amp on Full Active
    Audison Bit Ten Processor
    STP Deadening
    Audiomaxx wires
    Question, why did you decide to put in a processor? I'm trying to decide if I should get the new Xtrail 2.5 (no leather seats, so so stereo) or the new CRV 2.0S (smaller engine, leather seats, 7" multimedia stereo). As you know I'm a bit of an audio hobbyist. :-)
    Feb 2011
    #568
    Quote Originally Posted by riccomina View Post
    chief! nice to see you here. the processor has multiple features, one of which is time alignment. time alignment is important for the proper imaging and it avoids localization of the speakers. this also allows me to go on full-active wherein, i have full control of the speaker's equalization without the use of a crossover. regarding equalization, this has a 30-band feature which should be more accurate than the stock settings. then another feature that i like is the receiver function, just like our AVRs/Integrated Amps in our home audio, it can accept optical/digital inputs as well as analog ones.
    Haven't updated that post, but I already have a sub(finally!) and a mono amp to power it.
    #569
    Which sub did you get for your crv?
    Feb 2011
    #570
    I got the Focal 25A4 powered by an Audison SR1D. The woodworks will be installed this weekend, will post the setup in my pdvd thread
    Jun 2010
    #571
    Guys, question, kung bibili kayo ngayon ng second hand crv. 2012 model 2.0 A/T. 1,425,000 ang bnew nung 2012. ( Di ako sure anong variant kaya sinama ko na )
    Nasa 15k kms odometer. Nasa magkano kaya fair na bentahan ngayon? May kapitbahay kasi ako nagbebenta 900k daw. Sariwa pa naman. Di ko lang alam kung tama lang price nya o mahal.
    Jan 2014
    #572
    Quote Originally Posted by Travis01 View Post
    Kung ako sayo tatawaran ko pa hanggang 820k
    alamin mo muna yung variant
    Feb 2011
    #573
    3rd gen sir or 4th gen? usually a car depreciates atleast 10% per year. so I think the price given to you vs the car's present value is pretty good for that price being offered. kung matatawaran mo pa, why not?
    Jun 2010
    #574
    2.0 S siguro variant kasi Andun price range. CBU unit Japan version pero nabasa ko mas ok features ng Thailand version
    Jun 2010
    #575
    4th gen
    Aug 2007
    #576
    Afaik, Japan version for the 4th gen crvs were TOTL and 2.4 li engines only.
    #577
    May 2.0 2WD yung CBU Japan. No side mirror repeaters, no sunroof, no i-MID. Etc..
    Sent from my LT26i using Tapatalk 2
    Feb 2011
    #578
    It looks like it is the 2.0 LX based from the price. The difference it has vs the thailand 2.0S are: no Multimedia display, no rear AC vents. No Cruise control, no side mirror led indicators, has a handbrake not the footbrake in the 2.0S.
    Jun 2010
    #579
    as for the depreciation rate, normally less 20% on the 1st yr,
    then 10% on the 2nd yr up to the 10th yr at least.
    so the price is reasonable enough, i think.
    Dec 2008
    #580
    ano po magiging effect ng magkaibang rolling circumference ng harap at likod? example 215 55 17 sa likod tapos 225 55 17 sa harap.
Honda CRV [continued]
