Page 33 of 62 FirstFirst ... 2329303132333435363743 ... LastLast
Results 641 to 660 of 1223
    Mar 2005
    #641
    buy a valve cover gasket na orig. any honda casa has it.
    I had mine replaced and nagpaquote ako sa iba bang places. Would you believe that the casa has almost the same price as banawe pasay auto supplies?
    They quoted a replacement but its just 200 pesos cheaper so why buy a replacement when you can get the original at about 650 or 750 pesos?
    Then why buy sa auto supply when its price is the same as the casa price? wherein sure ka na orig if you get it sa casa?
    When you buy the gasket have it installed sa servitek so makikita mo habang ginagawa
    Good luck
    Good luck
    #642
    the original valve cover gasket costs 650-750 bucks in the casa, and the non-casa costs 450-550 kesos.
    considering it's just a gasket, i'd have a hard time deciding..
    but that's just me..
    Apr 2015
    #643
    Meron na po ba nakapag palit ng drive shaft oil seal for crv 3rd gen? Saan po ba magandang magpagawa dito sa South? How much po ba inabot? May leak nakita kasing leak dun sa ilalim. Thanks
    Feb 2015
    #644
    Quote Originally Posted by sinnedycate View Post
    Had it done sa Honda Cavite. Cost around 1.5k. Check your valve cover gasket too baka may leak din.
    Apr 2015
    #645
    Thanks sir!
    Nov 2013
    #646
    jasonub's
    Good luck
    dr. d
    maraming salamat sa reply, ngatanung nga ako sa honda bgc, 659 i think yung gasket, hanap na lng ako servitek dito sa min. maraming salamat uli :D
    jasonub's
    Good luck
    dr. d
    #647
    Anyone knows where I could buy a genuine Alternator for my 2007 CR-V (3rd gen)? Honda SPA is asking a whopping 66k for it
    Mar 2004
    #648
    Try PartStar in Taft Avenue, Pasay
    May 2011
    #649
    Does anyone know where can I buy tire cover for crv 2003?
    #650
    How will you know that your car was given a Permashine before release from the casa and not just something that they place in the proposal?
    Aug 2006
    #651
    Mga Bossing/Gurus,
    planning to buy a CRV Gen 3 (2007-2009) budget permits, ask ko lang po kung ano ang difference beetween 2007 from 2008 to 2009? in terms of FC and ride and accessories? 4x4 po sana yung balak ko. pang pamilya ( oldies ) kasi medyo lumalaki na po ang pamilya eh at need the leg room narin. nag check po ako dito at sa ******* eh nasa 500-700K (2007-2009) ang range ng CRV gen3. tama po ba yun or medyo me kamahalan? Knowing Honda. mataas parin ang resale value. maintenance wise and FC , is it advisable to buy an 8 yr old car? thanks in advance mga bossin.
    May 2015
    #652
    Hi Guys,
    May alam ka bang nag se-service ng ignition key ng honda crv 2003~2004 model, i just tried a duplicate key then yung original key hirap na rin pumasok pero gumagana naman, parang may tinamaan sa loob ng key entry, naita ako sa youtube, linis at spring replacement lang yung pinakitang solution, problem ko lang i wanted a reliable key servicing guys... can you recommend one ASAP lang aksi... and sorry if short notice.
    Thanks!
    Hi Guys,
    Thanks!
    Quote Originally Posted by slow_jun View Post
    Mga Bossing/Gurus,
    You're looking at the wrong car if you need the legroom
    Dec 2002
    #654
    Quote Originally Posted by bryan19 View Post
    I bought mine at Mega Cartronics along Del Monte Ave. It cost around 6k that was more than a decade ago.
    Today I went to Cartronics to buy one lug nut lock cost 700 pesos, I removed the tire cover. Macho factor improved plus 1.
    May 2011
    #655
    Quote Originally Posted by RC-V View Post
    Wow ang mahal 6k bili na lang din ako ng nut lock t will just cost me 800 sa mall ah hehe
    Anyway does anyone know kung bakit umingay un makina ng crv pag idle? Pag nag rev ka onti mawawala tapos babalik ulit pag idle? I already checked all fluids ayos naman un pan belt ba un pansin ko naging malangis siya dati un hinawakan ko un di naman malangis di nadumihan kamay ko noon ngayon ang dumi na haha. Next schedule oild change next month pa. Last December change oil at change coolant lang naman ginawa at some checking un mga dapat palitan. Dati kasi tahimik un andar even idle un crv pero ngayon may ingay na. I will try to post a video later regarding sa noise ng crv ko
    May 2011
    #656
    Hi its me again I think un tunog is from aircon pag bukas siya tapos idle maingay tapos pag nag rev or natakbo na nawawala. Pero pag naka off un aircon wala naman tunog. Will upload video later so you hear the sound
    May 2011
    #657
    https://youtu.be/PakfMANZF-I here is the video sorry kung madilim pero rinig un difference nun sounds un malakas na noise is naka on un aircoun un medyo humina un ang naka off
    May 2015
    #658
    Check the AC compressor bearing, nangyari sa 1st Gen V ko yan, after long drive - Cavite - Subic - Alaminos Pangasinan - Vigan - Baguio.. When i reach Baguio dun na bumigay yung AC Compressor Bearing. Ok naman yung Temp ng AC, maingay lang talaga. Kaya ng umuwi ako from Baguio to Cavite parang Helicopter yung tunog ng V pag naka open ang hood. Replace agad ng AC compressor, presto wala ng tunog.. 14K ang damage.
    Dec 2002
    #659
    Pa-check mo muna sa reliable aircon shop. Tapos kung compressor nga may sira, sa labas ka bumili mas mura kaysa sa aircon shop.
    May 2011
    #660
    Quote Originally Posted by norelco View Post
    As expected nga when I google the problem yan din lumabas haha pero ganun ba talaga even na may lamig or walang problem un AC when in comes to the temp no problem at all. Pero un tunog ala helicopter nga ang ingay pag naka on un AC at idle. Pag nag pa change oil ba ko sa dealer same lang din kaya un makikita nila problem?
Honda CRV [continued]
