Results 1,161 to 1,170 of 1286
- Dec 2010
- 50
May 26th, 2019 11:08 PM #1161nasa cavite pero hindi ko pa contact....baka kasi may modus na ho hold up ka pag tiningnan mo...
- May 2019
- 2
June 3rd, 2019 06:49 PM #1162
- Jul 2019
- 81
August 6th, 2019 10:28 AM #1164Sorry car newbie. In 2019, okay pa ba to own sa 2007 Civic FD in terms ng price, parts and car repair shops?
October 30th, 2019 01:21 AM #1165
Magtatanong lang po sana. My dome light doesnt work. Bulb checked and found working. Posible ba na blown fuse kahit gumagana naman map lights ko?
- 54,230
October 30th, 2019 01:46 AM #1166check also the bulb socket or connectors. baka marumi lang, or bent out of shape.
of course, blown fuse is the next guess.
check your fusebox or fuse diagram, po.
see what other appliance shares fuse with the dome light, and see if that appliance works.
errr... hindi LED, ha?
kung LED, reverse the polarity.Last edited by dr. d; October 30th, 2019 at 02:31 AM.
October 30th, 2019 09:06 AM #1167
Thanks for the inputs, Doc! Based on the fuse diagram, all small interior lights should be assigned to a single fuse in the internal fusebox, and one in the under-bonnet fusebox. This might mean the fuse isn't the culprit, since my map lights are working. Might as well check tho.
If not, is replacing the whole dome light assembly normal?
- 54,230
October 30th, 2019 09:16 AM #1168if there is nothing wrong with the dome light assembly, replacing it would not result in the solvation of your problem.
the dome light switch may be the problem. but i do not know if you are capable of testing its integrity.
check if the wires leading to the dome light, are delivering electricity.
pull out the dome light assembly. that should expose the connecting wires. using a tester, check if they are delivering the electricity. if they do not... then you'll have to dig deeper into your car's wiring. that means, knowing the color coding of your wires in question, tracing them .... trabaho!
good luck.
October 30th, 2019 09:39 AM #1169
- 54,230
October 30th, 2019 10:11 AM #1170
True, a friend’s golf gti was sitting in his garage for close to a year na kasi walang parts IIRC...
China cars
