Page 117 of 129 FirstFirst ... 1767107113114115116117118119120121127 ... LastLast
Results 1,161 to 1,170 of 1286
    Dec 2010
    #1161
    nasa cavite pero hindi ko pa contact....baka kasi may modus na ho hold up ka pag tiningnan mo...
    May 2019
    #1162
    nakow Sorry bro. hindi ko alam sagot jan kasi automatic variant iyong akin.
    Baka iyong iba dito makasagot sa tanong mo.
    Ok sir salamat po.. Another question i just had an oil change 10w 40 yung ginamit na oil ok lang ba yun? Any recommendations po?
    #1163
    Quote Originally Posted by cyhernandez View Post
    Ok lang yan. But that's semi-synthetic di ba?
    Pero para sa akin mas magbebenefit ang r18 (or k20) engine mo at ikaw na din kung mag fully synthetic ka na. Mas protektado at mas magiging efficient takbo ng engine mo
    Jul 2019
    #1164
    Sorry car newbie. In 2019, okay pa ba to own sa 2007 Civic FD in terms ng price, parts and car repair shops?
    Feb 2018
    #1165
    Magtatanong lang po sana. My dome light doesnt work. Bulb checked and found working. Posible ba na blown fuse kahit gumagana naman map lights ko?
    #1166
    check also the bulb socket or connectors. baka marumi lang, or bent out of shape.
    of course, blown fuse is the next guess.
    check your fusebox or fuse diagram, po.
    see what other appliance shares fuse with the dome light, and see if that appliance works.
    errr... hindi LED, ha?
    kung LED, reverse the polarity.
    Feb 2018
    #1167
    Thanks for the inputs, Doc! Based on the fuse diagram, all small interior lights should be assigned to a single fuse in the internal fusebox, and one in the under-bonnet fusebox. This might mean the fuse isn't the culprit, since my map lights are working. Might as well check tho.
    If not, is replacing the whole dome light assembly normal?
    #1168
    if there is nothing wrong with the dome light assembly, replacing it would not result in the solvation of your problem.
    the dome light switch may be the problem. but i do not know if you are capable of testing its integrity.
    check if the wires leading to the dome light, are delivering electricity.
    pull out the dome light assembly. that should expose the connecting wires. using a tester, check if they are delivering the electricity. if they do not... then you'll have to dig deeper into your car's wiring. that means, knowing the color coding of your wires in question, tracing them .... trabaho!
    good luck.
    Feb 2018
    #1169
    good luck.
    Thanks again, Doc. Seems like a bit more of a problem than I expected. At least, it is not a major one!
    #1170
    kuha ka ordinary bulb that you know, works, because you saw it glow.
    install it and see if it lights.
Honda Civic FD Body [continued]
