Results 21 to 29 of 29
- Apr 2015
- 28
- Apr 2015
- 28
May 12th, 2015 12:42 PM #22Ginamit ko kotse ko ngayon. Nag karga ako 500 from almost empty.
Marikina-UP Diliman- Taguig almost 200+ nakonsumo sa gas.
Masyado atang malakas.
- Jan 2015
- 468
May 13th, 2015 08:14 AM #23^^^sa tirona hiway, kung galing coastal, pagkanan sa sm bacoor, mga more or less 800 to 900 meters away.
- May 2015
- 3
May 17th, 2015 06:03 PM #24
August 28th, 2015 04:40 PM #25
i have 98 vti too. same din po ng problem except ung sakin pag uminit na sya nagloloko ayaw din kumagat yung 2nd nagrerev lng na parang neutral then kusa din sya kumakagat afterwards. same din po sa reverse ko minsan pumapalya din pag mainit na pero madalang nman po mangyari mas madalas po gumagana nman. seal din po kaya problema nito?
- Nov 2015
- 5
November 15th, 2015 05:32 PM #26Hi. Need advice. Ung transmission ko kase may problem sa reverse. Delay ung response ng reverse shift tapos nung pinacheck ko ang problema daw is wiring dun sa inhibitor na nagcoconnect sa transmission ko. True po kya un? Ska magkano ba pagawa ng wiring?
- Jun 2008
- 1,741
- Nov 2015
- 23
November 16th, 2015 02:53 PM #28Hi guys. Base sa mga nababasa ko, do you think it would be better for me to buy a CRV na manual transmission? Or nagkakaproblema din tulad ng ganito? Balak ko sana bumili ng 2nd hand 2nd gen CRV. Salamat.
- Dec 2015
- 1
December 9th, 2015 09:39 PM #29Hello po, balak ko po sana bumiili ng car na used before mag pasko. Ano po kaya ma susuggest nyo na auto? Matic po sana. 20 Y.O palang po ako.. Budget ko po is nasa 80-120K lang po..pwede nyo po ako email sa mga may binebenta support*manilasfashion.com
Having problems posting images as well.
Problems with viewing Tsikot on non-Chromium...
