Page 133 of 265 FirstFirst ... 3383123129130131132133134135136137143183233 ... LastLast
Results 2,641 to 2,660 of 5300
    Dec 2017
    #2641
    Quote Originally Posted by Bokyoo View Post
    Yes bro aside sa rattling noise may bago na naman sakit crv namin. I've read the lemon law just in case. The casa must try to fix the problem first, on the 3rd or 4th try pag di pa din naayos then pwede na mag file sa DTI. Pero sana di umabot sa ganon kasi that's so time consuming. Ang hirap lang nito it's our only car, nid tuloy mag Grab e pag rush hour umaabot ng P400 pamasahe. E sa crv yung P100 na gas sobra-sobra pa.
    Insist that if they will not give you a service unit, they have to pay for your transpirtation expenses
    Sep 2014
    #2642
    naku dba eps yan crv na yan, pano maging stiff or heavy ang manibela nyan, ibig sabihin electronic problem na yan. that's a new problem na.
    Oct 2017
    #2643
    Quote Originally Posted by montro View Post
    Thats the main thing, your crv serves as experimental unit until they found the solutions. Dapat pahiramin ka nila ng unit para magamit mo. Pwede mo iinsist sa kanila since that is your only car to used to.
    Sent from my iPhone X using Tapatalk
    They said they'll try to fix it till tomorrow, if it can't be done sabi nung SA na kausap ko pahiramin daw muna kami ng car sabi ko kasi susunduin ko si misis sa airport on Monday. Pero di nya sinabi if on that day lang ba nila ko pahiramin ng car or till mabalik sa min yung unit. I hope it's not just empty words.
    Oct 2017
    #2644
    Quote Originally Posted by Bedista11 View Post
    Yes bro will tell them that. Instead of just enjoying our new ride magkakasakit pa ata ako because of the stress created by this problem.
    Jun 2008
    #2645
    any suggestion on floor mat / liner & trunk tray?
    Oct 2017
    #2646
    anyone can fix this problem
    already try the tips in this forum and youtube nothing happens
    usb mp4 files
    #2647
    Just got the CRV back from the detailing shop. Availed of C.Quartz coating for 10.5k at ATMT Car Care. Let's see how this stacks up vs the regular carwash and wax regimen.
    Mar 2004
    #2648
    That is why some people avoid buying the first batches of a newly released model ...
    Oct 2003
    #2649
    Nice! Mura na ha. C.Quartz UK edition? Or C.Quaartz Finest?
    #2650
    Quote Originally Posted by zechs View Post
    UK Edition lang. Mas mahal yung Finest eh.
    Oct 2017
    #2651
    Solved na stiff/heavy steering wheel. They deliberately tightened the steering wheel to see if the knocking sound will be fix. Unfortunately nandun pa din. The problem is nakalimutan nila ibalik sa normal setting yung stiffness ng steering wheel kaya matigas sya when i drove it. They just adjusted it through computer and its now ok.
    Aug 2017
    #2652
    So only the knocking sound really the main problem. The steering problem is cause by negligence of the casa to set back to the normal setting of the steering wheel when they are looking the knocking sound problem and now ok.
    Oct 2017
    #2653
    Yes bro the knocking sound is still there. A while ago when i drove it passing on rough roads i also heard a clunking noise, sounds like metal. It's not the same rattling sound I've been complaining before.
    Nov 2017
    #2654
    Sir jut forgive me for my innocence. Anu po advantage pag nagpa car detail?
    as the name implies. detailing or cosmetic detailing or automotive detiaing is improving appearance inside and outside. paint detailing's goal is making the paint look perfect.
    protection via wax, sealant, coat, film are different ways to protect the detailed vehicle.
    best free photo upload sites
    #2656
    Quote Originally Posted by dongmilot View Post
    Glass coating keeps your car shiny and protects it from swirl marks and hairline scratches, so basically it has the same effect as regular waxing.
    Pros - you just do it once and you're done. Cons - expensive, and tbh it doesn't look that different from a car without glass coating.
    Dec 2017
    #2657
    from experience, glasscoats/ceramic coats aren't really an end-to-end solution to scratches or swirls. swirls can still develop (and be seen in spotlight/sun) with improper washing technique.
    otherwise, they do make cleaning much easier and our dark grey paint stays cleaner for longer between washes.
    #2658
    to the true-blood aficionadoes, "every little bit helps".
    to the everyday person, "it doesn't matter if there are swirls or not".
    #2659
    Quote Originally Posted by drew_cc View Post
    Kahit naman wax magkakaswirls din. And I've come to accept that swirls are a part of life. It's not something I stress about anymore. [emoji16]
    Dec 2017
    #2660
    amen to that.
2017 Honda CR-V Turbo and 7seats
